Cat Delete - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-08-2011, 02:52 PM Thread Starter
ckyguy68's Avatar
Cat Delete
Hey guys I am buying an 05 PSD next week, already put a down payment on it
The truck already has an aftermarket catback (not sure on the brand) and what seems to be a 3.5" downpipe (def. not stock). It does, though, still have the stock cat. I was wondering if this will be a tricky situation where I will need to measure out everything, or if I can just buy a bolt in cat delete like this one.
Parleys Diesel Performance: MBRP Stainless Steel Catalytic Converter Test/Delete Pipe for 2003-2007 Ford 6.0L Powerstroke
I have access to a welder and I'm not worried about that, but just curious if anyone knows how simple it is to slip a delete in between aftermarket pieces.
Thanks guys!
ckyguy68 is offline
post #2 of 15 Old 03-08-2011, 03:01 PM
MWilbur516's Avatar
I cleaned mine out with a sledge hammer and a 4ft piece of 1 3/4" EMT. The stock downpipe is 3.5". You may have a 4" downpipe or even a 5". You may experience some rubbing with the 5", if that turns out to be what you have. To answer your question yes you can just buy a bolt in cat delete pipe from whoever manufactures your exhaust system. If its a larger size than stock, a cat delete pipe will allow your engine to get full use of the exhaust by eliminating the restrictive cat and the bottle neck with the smaller stock pipe.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #3 of 15 Old 03-08-2011, 03:12 PM Thread Starter
ckyguy68's Avatar
Thanks for the quick reply!
This would probably be easier if I had the truck already and wasn't speculating
But I think I would like to keep the cat just in case! So I'll need to figure out what kind of exhaust I have.
As for the downpipe, it didn't look like a stock unit to me. It looked to be stainless and didn't have a heat shield or anything. No rust, very clean. The truck has 75,000 miles on it but I have a feeling it's aftermarket.
ckyguy68 is offline
post #4 of 15 Old 03-09-2011, 10:29 AM
Any problems passing emmisions after the cat clean out?
philmc12 is offline
post #5 of 15 Old 03-09-2011, 10:53 AM
MWilbur516's Avatar
No emissions in GA for anything 3/4 ton and up, gas or diesel. No emissions testing for diesels in GA at all. One more reason to go with the green pump.
post #6 of 15 Old 03-09-2011, 11:04 AM
Diesel emissions is rediculous anyways. GA sounds like a good place to be. Any emissions stricken people have any insight on this?
philmc12 is offline
post #7 of 15 Old 03-09-2011, 12:47 PM
MWilbur516's Avatar
Buy the cat delete pipe, then you can run without the cat until emission time and you just slip the cat back in.
post #8 of 15 Old 03-09-2011, 01:28 PM
Feedback Score: 3 reviews
Its not a CAT its a resonator for sound only. The only time it would be a "Cat" is a DPF which has two sensors one before it one after it just like a gasser.
96F350KID is offline
post #9 of 15 Old 03-09-2011, 02:20 PM
Power2336's Avatar
I have a straight pipe exhuast with 4" down pipe and live in SoCal. Took it to smog and the tech didnt even notice it was removed. Half the time the smog places may not be familiar with diesels and you can geget away with it. If your worried jist buy some clamps, weld them to yoir cat/resonateor then do same to a test pipe and bolt it in and out when needed if needed. You will love the sound to say the least.
RCD 4.5" lift with Airlift system, 4" MBRP turbo back minus KITTY & MUFFLER, AFE Stage II Pro Gaurd 7 intake, SCT X3 with Custom tunes, EDGE CTS for gagues with Pyro Probe, ARP studs, BPD Egr, Updated FORD oil cooler, Diesel Site Coolant Filter, AirDog II, 6.4 Banjo's, Upgraded BLUE fuel pressure spring, autometer in cab fuel pressure gaugs, Mag Hytec rear Diff cover, Full HID Xeon lights with HID Foggs, Recon LED tail and 3rd break lights all on 35X12.5R20's Toyo M/T's, XD Misfit rims.
Power2336 is offline
post #10 of 15 Old 03-15-2011, 04:43 AM Thread Starter
ckyguy68's Avatar
So I have my truck now and the truck has an MRBP exhaust which I am happy to have discovered. It still has the large resonator (what I thought was the cat) in place and I'm going to order a delete for it. Is this going to trigger a check engine light? If so will a SCT take care of that?
ckyguy68 is offline
