Ultimate tow upgrades - Ford Powerstroke Diesel Forum
Old 03-05-2011, 08:09 PM
Just curious what your guy ideas are on upgrade for towing. I tow a 28' camping trailer(7900lbs) and a quad in the back(600lbs). I think I have an injector I'm going have to replace so I'm not sure if I should go to 155's or keep stock and upgrade turbo or maybe go with IDP compound set up and what else will I have to upgrade. I tow the trailer every 4 day in the Sumer. What do you think?
Thanks
Old 03-05-2011, 08:22 PM
Feedback Score: 9 reviews
8-hole 155cc Innovative Injectors, AirDog 2 (along with the upgraded FPR kit and 6.4 banjo bolts), PowerMax Turbo, and an aFe Stage 2.
Also, you definitely need gauges (EOT, ECT, EGT, Fuel Pressure at the least) and an SCT w/ custom tunes if you don't already.
Old 03-05-2011, 08:35 PM
I did do the banjo bolts when I did my head stud forgot to ads them sig. I should have done some more reading on here and did the FPR while I was at it. Is the air dog 2 some thing that should be done first. I was looking at the fuel pressure for sure was on I was going to get.I have the egt all ready
Old 03-06-2011, 03:18 AM
Ultimate upgrade would be 225s and compunds
Old 03-06-2011, 07:59 AM
compounds are ridiculously expensive.... unrealistic.... i tow a 40' hauler all the time average 16k... once off warranty im building what i believe will be the ultimate tow machine.... as seen in sig.
Old 03-06-2011, 08:08 AM
the op said he was considering compounds, Thats why I recommended it. If I was building the ULTIMATE (key word here) tow rig thats what it would be.
Old 03-06-2011, 08:11 AM
So with the 225s, will the compounds help keep the EGTs down? With a single, I know 225s would be waaaaaay too much for towing heavy.
Old 03-06-2011, 08:17 AM
yes
here is shawn's new tow truck
went and picked up a cat 277 skid steer which weights 8k and the trailer weights 4k, i was very, very happy with the way the truck towed. full list of mods are
225cc stix 100 over noozles
s362 and s480 twins
BD intercooler
BD diverter valve for quick turbo spool up
Fass fuel pump, drilled out factory banjo bolts
arps and egr delete
Innovative Diesel tunning
Trusted Diesel oil filter relocation kit
all work done by a drunk canadian redneck(almost suprised it started)
Old 03-06-2011, 08:28 AM
Crazy. I'm assuming his EGT probe is hooked up to the exhaust manifold...
Old 03-06-2011, 08:31 AM
yes sir
