power steering fluid flush - Ford Powerstroke Diesel Forum
Old 03-04-2011, 09:13 AM
Two questions:
Can I use Mobil 1 syn atf fluid in my PS for an 04' 6.0? or should I stick with the mecron v from ford?
is this the best procedure to flush my ps pump?
Ford Super Duty Power Steering Flush | Superdutypsd.com
thanks in advance
Old 03-04-2011, 10:26 AM
That ought to work.
Old 03-04-2011, 10:51 AM
is that mobil 1 fluid the good stuff?
Old 04-11-2011, 09:29 AM
did the ps flush over the weekend, with good results. The old fluid wasn't too bad though.
Also replaced brake fluid while I was at it, unbelievable how much firmer my pedal is! brake fluid that I was sucking out was black!
Old 04-11-2011, 10:16 AM
How did you replace the brake fluid? Did you flush that also?
Old 04-12-2011, 04:16 AM
sucked most of the fluid out of the resevoir with my mityvac, dumped in new.
Started at the pass rear caliper and worked my way to the driver front. sucking out the old black fluid until it was clean. make sure to keep an eye on the resevoir so you don't draw in air.
pretty simple job just need the mityvac tool.
Old 04-12-2011, 04:17 AM
heres a link if you don't know what a mityvac is...
Mityvac
they make cheaper plastic ones, got mine from sears like 8 years ago and use the thing constantly.
