Confused about exhausts
So I wanna get a 4in and I wanna be able to take the cat on and off. I know i can get the turbo back on-road and a delete pipe and that works, but can i do the same with the off-road? Basically i'm just asking whats the difference between the two i guess..
Ok if i get what your sayin the off-road kit does not have a cat in it. Usually those are either straight pipes or have only a muffler. The on-road either has a cat with it or uses the stock cat. Depending on what you want to do you could go to a muffler shop and get a piece of 3.5" pipe and just cut your cat out. Then you could just clamp the cat in and out. Hope that helps!
The "offroad" exhausts are just a straight pipe all the way through and have to be cut and fitted with a delete pipe or your cat. Also the ones that use your stock cat go down to 3.5" to use the stock cat and the offroad exhausts are 4" all the way through I beleieve. I went with the 4" tb and the cat delete.
Ok thanks. I think I'll just get the on-road and get the cat test pipe.
You can just have 4" to 3.5" reducers welded to your Cat and then use 4" band clamps to hold either that or a same length 4" tube in the exhaust. Perfect solution and take you about 15 minutes to swap out when needed.
Thats a good idea. Basically what I'm getting at is I know the cat has that special end on it and I just wanted to know if you got the off-road would your cat be able to be put in if need be or do you just have to get the system that allows for the cat.
I dont want to but should I need to put it on for tests I can. I live in California too
Its not a cat. Get rid of it and be happy
Pm sent
When you get done it will look like this at both ends of the pipe or the cat. Very sturdy and it won't leak. It doesn't crush pipes so it is easy on easy off. Just butt the 2 sections together and wrap the band clamp around it.
