Boots! i need boots! - Ford Powerstroke Diesel Forum
Old 02-28-2011, 06:05 PM
guys im looking all over for aftermarket boots to fit my 6.0 im looking for either a 2.5" to a 3" 45 degree or even a 2.5" on both sides (thats the easy one) and also i need a 3" to a 3.25" stright about 6" not so easy to find. i have checked out vibrantperformance and als verociosperformance and no real luck there either. is there any out there that off a kit for the 6.0 or do i need to keep looking. thanks
Old 02-28-2011, 06:09 PM
Retired Coastie
Try dieselsite.com. Look on the left side under categories and go to "hoses, boots & clamps". They have em.
Old 02-28-2011, 06:10 PM
Feedback Score: 3 reviews
What he said^^^^^
http://www.dieselsite.com/index.asp?...ROD&ProdID=804
Old 02-28-2011, 06:14 PM
You can also check detroit flexible metal hose if you are doing aftermarket stuff. I have been to their store and they carry a ton of silicone rubber boots.
Old 02-28-2011, 06:37 PM
That's the issue, silicone, with the CCV pushing oil vapor into the IC, there is oil that puddles up on the inside of the boots. Silicone and oil don't mix, it eventually destroys the boots and you got to replace them again.
Old 03-01-2011, 03:00 AM
I got mine from Riffraft diesel.
They are less than Dieselsite and a nice product.
Old 03-01-2011, 02:53 PM
If you're looking to replace your OE boots, then BD Diesel offers a direct replacement kit which is fairly nice. I have them on my 6.0 and they run under $200 iirc.
Old 03-02-2011, 12:19 PM
Try siliconeintakes dot com. Great prices and they'll have what you are looking for. My stock silicone boots have lasted 5.5 years. If I need to replace the next set in 5 or 6 years so be it.
Old 03-02-2011, 04:10 PM
Buy new silicone boots and do the CCV mod. Even if you buy the Stealth CCV kit and new stock ford boots from Tousley Ford, you're still spending less than most of the aftermarket boot kits and you're removing the oil from the intake.
