Going back to stock lift - Ford Powerstroke Diesel Forum
Old 02-24-2011, 10:41 AM
I took out the blocks on the rear. Is there a add a leaf on the front? If I take out the add a leaf the front leaf spring pack will consist of 2 leafs is that ok ? I don't want it to break. The front sits about 1"-1 1/2" higher than the back.
Old 02-24-2011, 10:42 AM
I changed the front shackles to.
Old 02-24-2011, 05:09 PM
Stock there are only two leaves, it should be fine.
Old 02-24-2011, 05:10 PM
And stock it sat higher in the back, hope that helps
