how much ELC?
well next week im going to take my truck to ford and let them do a coolant flush..and im going to give them new elc coolant to put back in. how meany gallons do i need to get?
4 gallons of concentrate. The problem with this approach is that they will just fill with tap water thereby introducing minerals like iron that you just flushed out. This significantly undermines the life cycle of the ELC but it does get rid of the silicates.
well how meany gallons of destealed water would i need and ill take that for them to use too?
If they get it Completely Dry First ??? , you should have a capacity of 28qts +- a hair , so whatever is left after you take x-amount of ELC
Is the dealership using a machine? That'll make a big difference on how much you need and if you want the concentrate or the 50/50.
so its not safe to let ford do the flush?
