SF3 or X3???? - Ford Powerstroke Diesel Forum
Old 02-19-2011, 09:42 PM
SF3 or X3????
I am getting ready to order a tuner. Should I go with the SF3 or the X3? I know the sf3 comes with canned tunes as well as the ability to store customs and the x3 is customs only. are there any other differences in the two? any reason to NOT get the SF3?
Old 02-20-2011, 05:09 AM
Illiana Chapter Director
If you aren't going to be able to buy custom tunes right away, go with the SF3. If you are going to order custom tunes when you order the SCT then go with the X3.
Old 02-20-2011, 05:17 AM
Feedback Score: 3 reviews
The only difference is the SF holds canned and custom tunes. The X3 only holds custom.
I have a original X3 that holds both canned and custom, which they changed the name to SF a couple of years ago, most members including myself never use the canned tunes once you try a custom tune. If you plan on running custom tunes, then buy the X3 from someone who includes the custom tunes in the price of the X3, it's cheaper that way.
If you go with the newer X3, just make sure you download the right software for it off the SCT website, don't confuse it with the older X3 software which takes the SF software. It would also be a good idea after your set up and running to save your stock file to your PC, then save your custom tunes and your stock file to a flash drive or another device separate from your PC, just incase your PC takes a chit and you lose all your tunes.
