Tuner Problems SCTx3 ?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-19-2011, 01:18 PM Thread Starter
Was running the STREET Tune and programmed in the LOONEY , I started to get down the road and had to gas it to merge into traffic , soon as trans shifted it started to Shudder Really Bad !!! I mean like going over potholes something terrible !!
I stopped and reprogrammed back to STOCK and trans shifted perfect again ....after about 50 miles I figured stock suxs so I put the Street Tune back on and it shifts OK Now still ...What was up with the LOONEY ?? I have ran it before without an issues .......is it because I went from Street to LOONEY without going back to stock first ??? I want to run the Looney but not if its gonna Trash my Transmission !!!
any Ideas what was going on ??
'05 F250SD > Ranch Hand HD Bumper w/skid plate & KC's, 2.5" Leveling Kit, Firestone Rear Bags, 305/17 Goodyear Wranglers, Hide-a-Ball Hitch, SCTx3 by Vivian , EGR Delete, 4" open exhaust , 6.4 Banjo Bolts , Fuel Reg. upgrade kit , cold air intake by me , '03 Turbo by HPTurbochargers,46 gal.aux.tank, ARP Studs / Factory Gaskets.
Rmorgan711 is offline
post #2 of 12 Old 02-20-2011, 06:37 AM
Hmmm... I have the same tunes as you and an 06. I programmed Street and ran it for a week or two then programmed directly to looney. No problems?? I seen a couple say after you program to run through all the gears at part, half and wot throttle to get the tranny to re-learn?
06 F-250 4X4
08 rear bumper and taillights,
Shaeffers 9000 5w40 don't use in your 6.0
GOGO direct solenoid, 08 tranny pan and filter
Edge CTS w/EGT probe.ARP 4" silverline,
fuel pressure reg upgrade, coolant filter, pre-pump spin on fuel filter, ELC,Oil bypass
SCT custom tunes by Vivian@QT and Matt @GH
4440 Front, 3040 rear, 7480 gross. VXCF4
worldwide73 is offline
post #3 of 12 Old 02-20-2011, 07:08 AM
jay diesel's Avatar
I am pretty sure that you should return to stock before loading another tune. Have done this many times with no problems
2007 f-250 crew cab lariat fx4
4" Turbo Back mbrp with a missing kitty cat
edge insight cs
SCT tuned by eric @ innovative diesel
ARP studs
Bullet Proof EGR cooler
banks power elbow and cac tube
jay diesel is offline
post #4 of 12 Old 02-20-2011, 08:24 AM Thread Starter
Gonna try it again today , back to stock then load Looney and see what happens , I loaded it when I first got the tuner ..but it was before I did my egr delete so I took it back off and just loaded the street
post #5 of 12 Old 02-20-2011, 10:36 AM
MOMBENZ's Avatar
Hello Richard,
I hope you are doing well! You don't need to go back to stock to download a tune but you can. Sometimes, and not always, the transmission needs to learn. A good rule of thumb when installing a file, any file, but in particular, your performance tunes, from any tuner is to:
Go through the shift points two times for about a half mile. For example:
Shift to 1st gear and stop
Do first and second, stop
Do first, second and third, stop
Do this through all the gears 2x's.
After this you can punch it and won't have any problems. If you don't do this, it may take 24-48 hours for the transmission to learn but it will adapt. It doesn't always happen but if you go through the transmission learning process you would avoid it, if it were to happen, at that instant.
If you have any questions or problems, please feel free to call me.
Thanks & I hope everyone is having a wonderful day!
Vivian
MOMBENZ is offline
post #6 of 12 Old 02-20-2011, 12:22 PM Thread Starter
Thanks Vivian ! :-) I reloaded it and will see what happens as I drive back to work this afternoon ( 150 miles +- )
post #7 of 12 Old 03-03-2011, 05:03 PM Thread Starter
Still having shifting problems with LOONEY !! Transmission does NOT like this Program at all now !! went back to stock and drove all day ...loaded the looney again ..same crap tranny shudders so bad about to shake my fillings out !! ;-(
post #8 of 12 Old 03-04-2011, 07:32 AM
Matt@SCT's Avatar
Have you tried and reloaded the tune back onto the device?
Matt@SCT is offline
post #9 of 12 Old 03-04-2011, 10:18 AM Thread Starter
no Matt ....I guess I will try that ? Tune works great untill you get about 1/2 to Full throttle shifts , I will try and re-load ... playing it safe and re-installing the street tune for now....
post #10 of 12 Old 03-04-2011, 10:56 AM
Matt@SCT's Avatar
What happens if you drive the truck normal and then tip into the throttle part way for the Trans to relearn? I really never seen this issue happen to the 6.0 diesels, I mostly see this happening to the 6.4 Trucks. I would recommend reloading the file and then try the relearn for the trans and see if that works, let me know. Thanks
Matt@SCT is offline
