Stock Budget Build - Ford Powerstroke Diesel Forum
Old 02-19-2011, 08:04 AM
Stock Budget Build
As the title states, im on a budget build.
Im thinking on a budget of about $5,000. A list of things performance wise would be appreciated.
I have an '03 6.OH.
-Regular cab if it makes any difference.
Shes bone stock and has 60K miles.
Any input would be appreciated!
Old 02-19-2011, 08:09 AM
I want your budget.
What are your goals, if any? Do you plan to tow with it? How much weight?
Old 02-19-2011, 08:15 AM
Budget is over the course of a longer period.
- I have no intentions to tow, maybe a small trailer for hauling toys or etc, on a rare occasion.
(Dirtbikes, fourwheelers etc.)
I do plan to plow in the winter if that does make a difference though. The truck has a plow mount bolted on.
Old 02-19-2011, 08:28 AM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
start with guages, exhaust, and SCT tunes, after that if you can spend the money i would do the EGR delete/rebuild the oil cooler, swapping over to ELC coolant with a filter, and ARP studs if money allows
Old 02-19-2011, 08:45 AM
Thanks,
I plan to do gauges as a very first thing.
- then to a turbo-back, possibly with stacks.
Old 02-19-2011, 09:33 AM
All input is appreciated! Anyone else?
Old 02-19-2011, 11:39 AM
say no to rolling coal
Exhaust
coolant filter
Gauges (including a fuel pressure gauge)
SCT w/ custom files
EGR delete and oil cooler
Air dog fuel pump & new banjo bolts, maybe a fuel cross over line
ARP studs
Modded FICM flash
That ought to eat up your budget...
Then you're ready to spend some real money on injectors, turbo, tranny.
Old 02-19-2011, 12:14 PM
throw a garret powermax in there after you get all the 6.0 basics done(egr, studs, fuel pressure gauge at least and sct with custom tunes)
Old 02-19-2011, 02:10 PM
coolant filter andn oil bypass filter
Old 02-19-2011, 03:23 PM
Thank you all!
For now:
1) Gauges, (boost, trans, and EGTs)
2) Turbo-back, grandrock big rig w/ mitres.
3) EGR Delete
... in no particular order. This is for now! Does anyone know of any really good deals on wheels and tires?
And also stacks for cheap?
- I have about a grand in hand, where would you put this on a stock truck?
