dropping 10k need advice
ok guys im bout to do everything! arp headstuds, egr delete, black onyx gaskets, oil cooler, coolant fush switch to CAT elc and little things on and on. but my question comes from this. thinks of going to cass 175s and a powermax turbo. but my question is do i need an airdog or anything like that. if so which one? and where from?
yes you will need an AD2 to feed more fuel to the injectors. you will also have to update your tunes. and a fuel presssure guage to monitor
ok ill pick up an air dog II tonight and a fuel pressure gauge. what kind of fuel pressure should i be looking for
I run mine at 60. It only drops to 58ish
Best price I found
The new AirDog® II Demand Flow Fuel Preporator® |
06powerstroke06 since you are running 190s and ill be running 175s should my psi be at 60 psi also or different? and another question. do you have your stock trans still or has the extra power tore it up?
Yes 60 is fine for all injectors. Stock trans so far, not saying it will last forever
ok thanks to all that have helped me. ill keep everyone up to date on all the work that gets done as it goes
