how much boost for modified truck?
i have a 2006 f350 auto 4x4 182k . ive read on the forums here that people with upgraded trucks are making around 30-35 psi of boost. My truck has a air filter 4" turbo back exhaust and sct tuner and i only make around 20 psi max. (according to dash gauge) which seems to work fine.
i was wondering if i should be making more boost? and will i notice a difference in power or anything with more boost? and if i can make more boost SAFELY without having to worry about head studs or anything like that? would adding a boost fooler help? ive read that if you have a tuner you dont need a boost fooler is that true? thanks Brendon |
more boost does not always = more power. Stock turbo works best at 25psi anything above that it is less efficient.
Snake is pretty much right on. I wouldn't worry about your boost numbers. Alot of 6.0 guys see roughly 20 on their factory gauges. Every truck is different. Personally mine will hit 25-27 stock, but that doesn't necessarily mean I am making any more power than a guy hitting 20-22.
20lbs of boost pushes my mule down the road just fine. I can hit higher boost numbers if I wanted.
If I mash mine to the floor I will see 20-22 psi. If I am in a high gear and low rpm and just roll into the throttle without it downshifting I see 30-32 depending on weather temp outside.
thanks for the help guys. i figured the stock turbo wasnt good for much more boost before it looses effeciency or i loose my head gaskets lol. i got the "custom" tunes from innovative diesel. i have economy tow and street. im not sure how "custom" they really are but they work good, really woke the truck up
Yep, I've pegged my 35 PSI gauge on the interstate rolling into the throttle (then popped an intercooler boot off
) but WOT from a 30 MPH roll I won't see over 28.
MY THEORY ON WHY YOU SEE MORE BOOST AT LOW RPM AND HIGHT LOAD IS THAT THE TURBO IS ONLY CAPABLE OF MOVING SO MUCH AIR AND WHEN YOUR ENGINE ( WICH IS BASICALLY AN AIR PUMP). IS AT A HIGH RPM THE TURBO CANT MOVE ENOUGH AIR TO MANTAIN A HIGH BOOST PRESSURE BUT AT LOW RPM IT CAN SO IT PRESSURES UP AGAINST THE LOWER DEMAND FOR AIR, CORRECT ME IF IM WRONG
