Will this work, egr delete with no tunes... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-01-2011, 10:52 AM Thread Starter
Kwattro's Avatar
If I install an EGR delete kit, like from Sinister Diesel, and leave the valve in the intake manifold and plugged in, will I still need a custom tune?
The El Cheapo Cooling Filtration DIY - It works!
_________________________________________________
-= 2006 F-350 SuperCrew 4x4 6.0L PSD =-
IIS Stage 1 Turbo, Warren Diesel 155cc/0% Injectors,
Swamps 58v FICM, PHP Atlas 40 Tune, PHP Gryphon Programmer,
5" Diamond Eye Exhaust, DieselSite Coolant Filter,
Knockoff EGR Delete, ARP studs, 33" Toyo MT's
Kwattro is offline
post #2 of 12 Old 02-01-2011, 10:59 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
You can do the delete but might get a check engine light.
dhanna6powerstroke is offline
post #3 of 12 Old 02-01-2011, 11:16 AM Thread Starter
Kwattro's Avatar
Even with the valve in the manifold and plugged in? The way I understand it if I set it up like I said the truck shouldn't "see" that there's a delete there since the valve is in place and connected. So I'm only guessing there will be no codes and I'll still have the benefit of eliminating that recirculated garbage in my intake.
Kwattro is offline
post #4 of 12 Old 02-01-2011, 11:20 AM
fordfreak4life's Avatar
05-07 knows when there is flow and how much there should be from the egr, if it has no flow, as the case will be with your truck, it will throw a egr low flow code. i would recommend custom tuning and roll with it
Yes its fast, NO YOU CAN'T DRIVE IT
fordfreak4life is offline
post #5 of 12 Old 02-01-2011, 12:20 PM Thread Starter
Kwattro's Avatar
Thanks guys.
Kwattro is offline
post #6 of 12 Old 02-01-2011, 09:12 PM
Ok so I just bought an 06 and it does have the sinister egr delete kit installed. There is no tuner on the truck and it is throwing a code. The previous owner has a code reader and he would just erase the code everytime it popped up. Is it ok to keep driving it with the code thrown. Is it necessary to get the tuner so I can delete the code? I am wondering if it will drive better or the same with the code thrown or not.
Imfinallystroken is offline
post #7 of 12 Old 02-01-2011, 09:56 PM
turbo347stang's Avatar
Well, here is my input on that...Having the code isn't really gonna cause any problems for you. However, when there is a problem, that would generally trip that check engine light, you aren't gonna know unless your checking for additional codes on a regular basis.
Just a thought.
06 F-350 CC, SB, Lariat- Insight CS, High idle, dieselsite coolant filter, 4" Diamond Eye, CAT ELC, 6.4 banjos w/reg kit, SCT w/MKM, SRL, or Looney, Leveled, PHP tuned 48v FICM, HID heads&fogs.
turbo347stang is offline
post #8 of 12 Old 02-02-2011, 07:07 AM
caissiel's Avatar
I have a canadian spec truck, 2005 late model and have deleted the EGR cooler and have normal operating features and no codes. The only thing that changed is that there is higher exhaust presures when cold due to vanes on the turbo closing to create faster warmup and a lack of power after cold startup until warmed engine. By shutting down the EGR Cooler the heated EGR flow is now blocked and the exhaust has to make its way through the turbo.
I have discovered that the EGR flow is also diverted by the turbo vane controls, that shuts turbo flow and increasing the Exhaust gas pressure that I can measure with my ScangaugeII.
2005, 6.0L, 6 Spd Std, 3.73 Rear End, F250SD, Extended Cab, 4 x 4 Long Bed. 2008 extension mirrors. GPS/TV/DVD/CD/Rear Cam/Radio installed, Max Energy programer by Hypertech, and Fuel Pressure Gauge. ScanGaugeII for 60 plus XGauges, and MPG. ELC Cat EC-1 Coolant, Pull a 39ft 15500Lbs 5th Wheel Camper Trailer. Mileage Avg is 20MPG, and pulling 12.6MPG.
caissiel is offline
post #9 of 12 Old 02-02-2011, 06:16 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
mine only throws a p0401 if i'm on the highway too damn long. freeze frame shows it coming up right a 60mph.
if i stay off the highway it'll never set a code
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 12 Old 02-03-2011, 03:59 PM
HOTWHEELS34's Avatar
I have an 05 with a delete, but I left the valve in and plugged in and I have no codes or CEL.
2005 F350 CC SB ,Turbo-back Silverline 304 ss , RCD EGR delete , Elite VGT-SS turbo , SCT tunes by DJ's , cat delete , Autometer triple gauges , 20" MKW M19 , Toyo 38 x 15.50 x 20 , Icon 4-link 10in. lift , Dual Sway-a-way coilovers and shocks , Pioneer Avic F90BT, OUO Driveline Drop, CCV reroute , FS-2500 oil bypass, Mag-Hytec diff covers , Amp steps
Wanting a Cummins swap.
HOTWHEELS34 is offline
