coolent filter systems - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-26-2011, 08:11 AM Thread Starter
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
what coolent systems are you guys using on your 6.0s iv been looking into the sinister kit, but i would like to get some other opinions or thoughts and also where does the filter lines tap into? anyone have pictures of their set up?
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
post #2 of 17 Old 01-26-2011, 08:27 AM
Ironmover's Avatar
Go with Bob Rileys kit from dieselsite. Best price, straight forward install and his is the original. It comes with a Baldwin filter with no SCAs which is important if you've already done yourself a favor by flushing and replacing your old coolant with ELC.
Sinisters kit has funky crimped ends on his hoses which I've had experience with before on others products where they fail and let the hose go.
I have the dieselsite kit and have no complaints. The feed side of the filter comes from your pressure heater hose which runs across the passenger side valve cover. You tee in there by the inline climate control valve and the return runs nicely over your fan shroud to a relief line going to your degas tank. The filter bracket is tricky to get the bolt started but once it's in it won't go anywhere! Real simple idea. My advice is to have a reach magnet handy and just be patient when starting the nut inside the core support. If I had pictures it would make sense to you but once you get the kit you get the idea. Also check fleabay, search for degas tanks and bypass filters and you get some alternative ideas for filter brackets.
Stock sucks
More torque pleeze
21st century participant of the 2nd amendment
Republican
Ironmover is offline
post #3 of 17 Old 01-26-2011, 08:47 AM
majek5's Avatar
I'm running the Dieselsite setup too. No complaints, and it adds some bling to the engine compartment.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #4 of 17 Old 01-26-2011, 09:49 AM
If you like DIY you can get a filter base from Wix and and a couple tees and hose and make your own. OR plug and play with Dieselsites.. I prefer to do it myself so I made up my own kit.
06 F-250 4X4
08 rear bumper and taillights,
Shaeffers 9000 5w40 don't use in your 6.0
GOGO direct solenoid, 08 tranny pan and filter
Edge CTS w/EGT probe.ARP 4" silverline,
fuel pressure reg upgrade, coolant filter, pre-pump spin on fuel filter, ELC,Oil bypass
SCT custom tunes by Vivian@QT and Matt @GH
4440 Front, 3040 rear, 7480 gross. VXCF4
worldwide73 is offline
post #5 of 17 Old 01-26-2011, 10:01 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
So does your transmission, your power steering, and your fuel lines! Are you really trying to say that a rinky dink hose clamp makes Dieselsite's kit a better kit? Plus with Dieselsite you have to buy the ball valves and the second filter that come in the Sinister kit.
So comparing apples to apples, Coolant filter heads, 2 ball valves, 2 spin on filters, all hoses and hardware:
Dieselsite = $156.96
Sinister = $125.
Same functionality. I don't have a horse in this race, just thought I'd point out some obvious things about each. Did somebody say FCDP?
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 17 Old 01-26-2011, 10:07 AM Thread Starter
STRKTHS73's Avatar
yeah i just noticed that sinisters kit comes with the ball valves and two filters which makes it a better bang for your buck plus u can always change their ends to barbs. i think im going to go with the sinister kit seems a little bit more thought out, PGreenSVT if you hadnt picked up on that comment i prob wouldnt have thanks.
06 F-350
edge cts insight
post #7 of 17 Old 01-26-2011, 10:14 AM
Gilstan's Avatar
Dieselsite cooolant setup is the way to go. Very easy to install good directions with photographs.
2007 F-350 King Ranch Dually 6.0, Edge Insight, Turbo back 4" MBRP Dual Exhaust, Where's Kitty, Garrett Powermax Stage 1 Turbo, ARP Head Studs, Sinister EGR Delete Kit, AirDog II 165, SCT w/Custom Tunes, Upgraded Fuel Pressure Spring, 6.4 Banjo's, Zoodad w/Metal Screen, CFM Intake, Jobe Air Intake,CAT ELC Coolant, DieselSight Coolant Filtration System, NUC Oil Bypass, & Amsoil Everywhere.
Gilstan is offline
post #8 of 17 Old 01-26-2011, 12:18 PM
Sesco4's Avatar
I just got my Sinister kit in yesterday and it seems to be of very good quality. As soon as the weather breaks I will be flushing my cooant and installing the filter kit. Most of the guys on here don't like the fact that the Sinister kit has the connectors crimped on the hoses. Also I don't think the Sinister kit has been on the market very long so you don't have many people running them where as the Dieselsite kit has been around and there is a bunch of them running there kit. Either way I think both kits will do the job it just comes down to what you want.
Sesco4 is offline
post #9 of 17 Old 01-26-2011, 01:37 PM
01redcrew's Avatar
Quoted: 2 Post(s)
where are you guys finding the sinister kit at on there website
also i found one on dfuser is that one any good? Thanks guys
2013 6.7 with stuff
01redcrew is offline
post #10 of 17 Old 01-26-2011, 02:04 PM
Sesco4's Avatar
Go on the MKM customs website and in the search box type in coolant filtet.
Sesco4 is offline
