Where did my power go - Ford Powerstroke Diesel Forum
Old 01-25-2011, 10:18 AM
I have been running idp ex street for a while now. My truck seems down on power. I have no puking so I don't think it's the head gaskets. I changed the fuel filters.
When I 1st put my edge insight on it ran a 14.8 1/4. Today it would only run a 16.4. What should I check out. I have no codes
Old 01-25-2011, 10:35 AM
Give some more info on the truck please. Year miles mods etc....
Old 01-25-2011, 10:45 AM
Sorry. It's a 2004 sb cc 4x4 auto trans 141000. Edge insight, sct sf3 idp ex street. Stock exhaust with no muffler or cat. Egr delete. 8" lift 38x15.5r20 I think that's it.
Old 01-25-2011, 11:03 AM
Pictures?
Does it ever have a hard time starting or crank for a long time before it fires?
Old 01-25-2011, 11:22 AM
No it starts right up. Even when cold. Some time when it below 40 it wil run real ruff for about 5 seconds then clears up.
I'm not sure how to post pics on here
Old 01-25-2011, 11:28 AM
Do you have a PhotoBucket acct? you can copy the image code and put it in your reply.
The only thing i can think of right off hand would be your HPOP is dying Maybe someone else will chime in and suggest something not so harsh....
Old 01-25-2011, 01:18 PM
Been doing a Lil reading. Looks like it could be my hpop or ipr. I looked and I do have a oil leak on the back of the engine.
Old 01-25-2011, 01:27 PM
I'd Defintely check your IPR then that should be where your leak is coming from and the cause of your low power
Old 01-25-2011, 01:43 PM
I have a 2000 7.3l with close to the same problem. it has a ts chip and it seems to hav lack of power and leaks oil from back of engine. what is IPR?
Thank you
Old 01-25-2011, 01:45 PM
Injection Pressure Regulator, I don't want to give you any advice though as im not as familiar with the 7.3 as i am the 6.0. Have you posted in the 7.3 Problems section?
