Coolant temp gauge - Ford Powerstroke Diesel Forum
Old 01-24-2011, 05:57 PM
Coolant temp gauge
Whats the best place to put my new autometer coolant temp sending unit.
I pulled the plug out of the motor under the driverside exhaust manifold no go its not a pipe thread. Need help Thanks
Old 01-24-2011, 06:34 PM
buy a coolant filter kit, the filter heads have blank ports that you have to put pipe caps on, you could put the sender there, thats what im doing ince i get the gauge kit for it
Old 01-25-2011, 10:28 AM
That's where i put mine, but the sensor the autometer gauge came with wouldn't ground out through the filter housing. so i had to buy a different sensor with a pigtail that had the two wires instead of just one so i could ground it to the battery. now it works perfectly
Old 01-26-2011, 03:37 PM
I used the drain port on the drivers side of the block. Im used the isspro gauge/sender/adapter. works great and temps are dead on.
Jason
Old 01-27-2011, 03:38 PM
Yah i wanted to put it on the side of the block. didnt realize it was metric thread untill about a half a gal of coolant in the face later. lol how much do those adapters run?
Old 01-27-2011, 07:21 PM
i think dieselmanor had them for like 5 bucks or something cheap like that.
