05 F250 6.0l which CAI? - Ford Powerstroke Diesel Forum
Old 01-23-2011, 01:42 PM
Hey guys im new to the diesel world and need some help deciding what type of CAI to run on my 2005 F-250 ccsb with turbo back 5" mbrp exhaust and SCT SRL tune by Matt i wanna know want to know what you like and dis-like thanks for the help
Old 01-23-2011, 01:45 PM
you dont need one yet. the stock intake is good for 500hp... id spend it on a ccv mod or something else your truck would like... maybe some gauges since you're tuned..
Old 01-23-2011, 01:48 PM
CCV mod?
Old 01-23-2011, 02:02 PM
Originally Posted by howell_jd View Post
To prevent combustion gasses that blow-by the piston rings from pressurizing the crankcase and blowing out engine seals modern engines have a crankcase ventilation (CCV) system (crankcase breather is the term used on the 6.0L). This is a positive crankcase ventilation system (PCV) and an emissions control device. On the driver side valve cover there is a crankcase breather that routes the vapor from the crankcase back into the air intake manifold via the turbo compressor. As oil droplets are picked up along with the combustion gasses that need to be evacuated you get some oil dropout through the compressor and CAC tube (hot side - passenger side). This oil will cause some degradation of the silicone boots connecting the turbo to the CAC tube and the CAC tube to the intercooler as well. This oil is what causes some to blow off CAC boots and lose turbo power or more significantly rupture the CAC boots requiring replacement of the boot rather than just reaffixing the boot. A CCV reroute with inline filtration catches the oil droplets in filter media but preserves the pressure balance for PCV operation. Rerouting the PCV to atmosphere as many commercial trucks do results in the odor of the crankcase surrounding the vehicle but more poignantly introduces the risk of evacuating the crankcase of oil if there becomes a pressure differential. Eliminating the oil from the PCV is easy, the catchcan just needs periodic draining (at each oil change). Maintaining the balance of pressure protects your engine and yes it keeps you in environmental compliance for emissions control if your state requires that at inspection time.
Jonathan
best explanation of it ive found... theres a couple people that sell it on here. raul@stealth automotive and kevin(nchornet) are a few...
Old 01-23-2011, 03:08 PM
The Lady Mod
Send a message via Yahoo to Granny
I agree with what has already been said. The stock intake is as good as it gets unless you are wanting to go big HP, by that I mean over 500HP. If you don't have gauges, get some. You are running tunes and you really need to be able to monitor what is going on under the hood, especially the EGTs. That is just my opinion.
Old 01-23-2011, 03:19 PM
I have a K&N CAI with a AEM Driflo filter. More HP/TQ and MPG.
I don't disagree that the stock intake is good to 500hp, but I do think that benefits and the cheaper filter cleaning is a lot better than replacing that donaldson for $75 each time.
Old 01-23-2011, 03:31 PM
i have an EGR delete and a Bully dog monitor ... what else should i get then ?
Old 01-23-2011, 04:13 PM
ccv mod, coolant filter and flush.... cool stickers, um i could think of a few more...
Old 01-23-2011, 04:16 PM
CCV is practically free if you can figure out how to make it yourself.
Coolant filter and a ELC coolant will go a lot further than a CAI. Hell those are ALWAYS one of the very first things I do or suggest to do to a 6.0.
