Hard to get truck to boost over 20psi
I have noticed that when i get on my truck the boost gauge rarely gets over 20psi. I might hit 30 with a boosted 4x4 launch MAYBE, but very rare. It is the way I drive, or is something up with my truck??
I have tried rolling into the throttle, and stomping on it quick, both seem to produce the same boost levels. When she does hit 30, the power is unbelievable, and I would like to see more of that!!! |
so you think the turbo is coked up?
Just remember 28lbs boost on a stock motor they will take it for a while you may need ARP studs and your truck could look like this
![]() 6 0L Ford Power Stroke Engine Head Bolt Problem Photo 1 2 stroker |
I have an unstudded tune, I wasn't sure if the tune was limiting it
it very well could be, it's better that way anyways
before studs my srl was producing close to 25
You could always pull off the vacum line if the boost means that much to you. I don't think it is real good for it, but it will increase your boost, I have a 6.4 that runs 38 lbs stock so I don't have that problem, I would like to run less boost and try to get better mpg.
scparrish, Nice bulldog. |
I could hit 29lbs all day long with my tunes. Non-studded tunes.
Mine will hit 25 stock, that correct? |
