cat delete help... - Ford Powerstroke Diesel Forum
Old 01-22-2011, 12:30 PM
cat delete help...
I'm trying to put on MT cat delete pipe from diamond eye. I can't get it to slums in the pipe far enough to get it to hook up the flange. Is there any tricks????
Old 01-22-2011, 02:19 PM
do you mean that you cant get it to go far enough back to get it to line up on the front flange. when i did mine today i unhooked the holders at the cat and the one right before the muffler and then restled it in. much easier.
Old 01-22-2011, 02:24 PM
Ok, I'll risk the cat.
What does it mean "to slums"?
Just curious.
Old 01-22-2011, 02:40 PM
I finally just took the whole exhaust out and got it to work. but the stock bolts wont work, so i have to use big *** zip ties to hold it together till i get to the store tomorrow to get new bolts...(That the only time ill be driving it that way... How do you like the way it sounds with the cat off??????
Old 01-22-2011, 05:07 PM
mine is a work truck that we are experiencing with. it had a regular sound with the cat on. and now it sounds like a vacuum at the tailpipe. to me it spools a little faster and the rpm's drop slightly faster. with my truck weighing in at 9980 pounds with all the tools im hoping it runs a little bit better. now when the egr deletes are in, turbo cleaned, and fuel pressure reg and bolts in we are hoping all our inherit problems will be gone. tie wraps are gonna melt pretty quickly. i did mine with flex pipe and band clamps.took a whole hour.
