heads r coming off - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-20-2011, 07:30 PM Thread Starter
borsky4's Avatar
heads r coming off
sooo looks like heads r coming off, already deleted so was looking for some input on additional mods to be made. Of course studs and black onyx gaskets, already got an sct just waiting for my mods to be finalized before getting my custom tunes.
I was thinking powermax, and tq converter, also tossed around injectors probly elite 8 hole 155's, i wanna stay quite streetable, and tow too. What r the specs on the powermax everyone is running? there is two on the elite website and the bigger one is cheaper?
probly better to run the smaller one for my application though? any recommendations for a converter? should i even bother? or go for the injectors instead? Also plan on the 6.4 banjos and regulator upgrade kit from ford. thinking of water meth too. or is that going to be too much to keep it reliable. I know thats a lot of questions just looking for ur two bits.
thnx borsky
borsky4 is offline
post #2 of 11 Old 01-21-2011, 08:14 AM
MUDSTROKIN''s Avatar
What year is your truck?
2005 F250 Reg cab LB XL
Airaid CAI
4" MBRP straight pipe from the turbo back.
RCD EGR Delete
Upgraded Banjo Bolts
Zoodad Mod
Swamps HOT FICM
Lariat Captains Chairs with woodgrain center console
MUDSTROKIN' is offline
post #3 of 11 Old 01-21-2011, 09:45 AM Thread Starter
borsky4's Avatar
the truck is a 2006 crewcab f-350 with 70k miles
borsky4 is offline
post #4 of 11 Old 01-22-2011, 09:29 AM
B3YOND's Avatar
Give the Elite 155's a try and you won't be disappointed. You could shim the fuel pressure spring if you had a fuel pressure gauge. You want the Powermax 2004-2007 (PN 772441-5001s), it's a GT3788VA turbo. Nice unit also, would match great with 155's (towing)-195's(street). Here is the comp map of the powermax vs stock.
2004 F350 Lariat Crew Cab SRW FX4
SCT Livewire - IDP, Gearhead, Spartan Tunes
MBRP 4" Turbo Back - Muffler w/no cat
B3YOND Banjo Bolt Upgrade
Dieselsite Adrenaline HPOP
Holley DieselPro Nitrous - Twin 10lbs - POD Heater & .073 jet (~200hp)
EGR Delete - TIG'd Stainless Cooler Plugs
Maxxlift 2.7" Leveling Kit
20" MB Gunner 8's and Nitto Trail Grappler 35x12.5x20
Viper 5901 Alarm/Remote Start
B3YOND is offline
post #5 of 11 Old 01-22-2011, 11:09 AM Thread Starter
borsky4's Avatar
thnx man any recommendations for a tq converter
borsky4 is offline
post #6 of 11 Old 01-22-2011, 11:44 AM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
thnx borsky
Here's my list for you:
-ARP Studs
-Black Onyx Gaskets
-Machined Heads for Flatness
-AFE Stage II Intake w/ Pro Guard 7 filter
-PowerMax
-4" MBRP TB Exhaust w/ Cat Delete (if you don't already have one)
-Innovative 8-Hole 155's ($2990, cheaper than Elite's, and Innovative builds from newly remanufactured Ford injectors, not somebody else's used cores. Not to mention Elite's crappy customer service can't even compare to innovative's great service.)
-AirDog 2
-Updated FPR Kit
-6.4 Banjos
-Moderate Tuned FICM from Innovative and Innovative Custom Tunes
I would skip the water meth and the torque converter. Your transmission should hold fine, as long as you change/flush the fluid every 30k. Only upgrade it if you just want too.
And BTW, you have good taste. This is my future mod list.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #7 of 11 Old 01-22-2011, 12:48 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Eric resells Industrial Injection fuel injectors if memory serves. I think I'd just stick with Ryan Casserly.
RIP Mitch
the Org crew
PGreenSVT is offline
post #8 of 11 Old 01-22-2011, 12:54 PM
Nope, he builds his own now.
And Casserly does not build 155's yet. Last I heard he was still working on them.
Blake
post #9 of 11 Old 01-22-2011, 12:55 PM
back in the saddle
shu873's Avatar
Unless Eric started something new, he has never built his own injectors before. He has dealt industrials and casserly's before. The ones on his site might even be hypermax since I know that's what they run in their "proven 1000 rwhp" trucks.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #10 of 11 Old 01-22-2011, 01:00 PM
I emailed Eric a few weeks ago to verify, and this was his response:
Yes, we have been building them for a long time, just keep them at a low volume. We are a little more expensive, but use Ford remans and brand new nozzles. We have a local OEM injector builder flow test each injector before it's shipped.
The price is $2950 plus your cores.
Thanks
Eric
Blake
