EGR delete ? - Ford Powerstroke Diesel Forum
Old 01-19-2011, 06:35 AM
EGR delete ?
I have an 06 f350 6.0 115,000 miles. The egr is out and needs to be replaced. I stopped by a repair shop. They said they weld the two ends of the egr closed and block were the old egr valve is at and it is better than a kit because it has support and will not rattle loose or leak like the kits. They also said the kits are just not flexible like the factory parts to allow for vibration. My question is this better and if this ok why isn't anyone posting on this furom about it?
Old 01-19-2011, 08:33 AM
if its already out ? why not spend another $150 and just put in the kit ? Otherwise you still have water flowing tru it and if it leaks could still push your head gaskets
Old 01-19-2011, 10:39 AM
Most of the kits I have seen have some flex built into them. I've never heard of any problems from anyone doing a delete.
Old 01-19-2011, 10:48 AM
'Merica
Sound like a bunch of BS to me.
Old 01-19-2011, 11:14 AM
I'll second that
Old 01-19-2011, 11:43 AM
Feedback Score: 3 reviews
Did that shop happen to mention that you will most likely need a SCT tuner in order to turn off the CEL you'll get from the lack of exhaust flow to the EGR valve.
Old 01-19-2011, 12:05 PM
What they're advising you to do is an EGR block, not an EGR delete. (not in the true sense). As others have mentioned, its a partial solution to one of the 6.0's weak links. However, a full EGR delete is the best option in my opinion.
Old 01-21-2011, 07:49 AM
thanks
thanks for clearing that up. I had already had bought a delete kit and oil cooler. The mechanic shop advised me to go with an H and S tuner, but reading this furom i will go with sct and will be looking for one.
Old 01-21-2011, 07:54 AM
I modified my stock EGR cooler and up pipe. I runs sweet.
My Solution for the EGR Problem.
Old 01-21-2011, 07:58 AM
I have been running my kit for almost 100,000k with no "flexing" issues.
