SCT can Tunes questions? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-17-2011, 04:29 PM Thread Starter
DJErlan's Avatar
I have a 2006 f250 4X4 and just installed an SCT SF3 today. I am not sure what settings I should be running. There is many options you can adjust other that the tunes it comes with. Can anyone give me a better understanding of the options or tunes. I set it at the performance tune with 100hp. Will this tune automatically set my top end speed as well? Only mods on this truck is a 4inch turbo back exhaust. Thanks in advance.
DJErlan is offline
post #2 of 3 Old 01-17-2011, 04:41 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The only setting that I would recommend playing with is. Set the gear ratio to what is in your truck, set the Revs per miles to what it calculates out to your tires, and the factory speed limiter is set to 98 mph you have an option to up it or remove it (Meaning no top end limit).
If you do mess with the shift pressure, only increase or decrease in 5% increments. But I personally wouldn't touch that or the shifting settings. You also have a option to increase the idle higher than stock, but I would recommend to leave it stock.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 3 Old 01-17-2011, 05:24 PM Thread Starter
DJErlan's Avatar
My concern was to lift the speed limiter, delete EGR, and set for new tire size. I really don't want to mess with any of the other things. I just wanted to make sure I don't mess something up. As far as furl economy, do you know which setting will be the best for everyday driving. I do not tow. Thanks.
2006 King Ranch 4X4, SCT Tuner, 4 inch Turbo Back Exhaust, 20 inch XD Hoss, 33x12.5 Terra Grapplers
DJErlan is offline
