Head studs under warranty
I am trying to figure out a way to get the arp studs done under warranty. Does anyone know of any dealership in Florida that is good to deal with and has done the stud job under warranty?
If you need head gaskests buy the studs and have them there durring the job. Ask to talk to the tech and then flip your mechanic $50 while you are dropping everything off. If you dont need head gaskets, ditch your EGR and Gold coolant and probably never have any head gasket issues!
well i dont hab head gasket issues but i want to put black onyx head gasket and arps in because i want to do injectors and turbo. Does anyone know of a way to be able to either make ford think i need head gaskets or something?
put a high tune on there and run that boost up they will let loose after a while
but at the same time if you got money to be doing new injectors and turbo why are you trying to chisel ford out of a couple bucks
Yea, if you are doing injectors and a bigger turbo, you will need them! Any motor will! If you have a good tuner, you should be fine even with just a tune and your EGR gone. We are running a few with no issues out here.
Of course, get some gauges to make sure your EOT and ECT are close. |
I got mine done in NC under the warrenty, but i had to provide the studs
my truck has never had any issue and is about to run out of 5yr waranty... i have wanted studs installed forever! but no work needed, my dealer said they would do it if my gaskets went out, but they never did.. im not the type to go force the problem!
