Got questions about head studs/ egr delete? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-09-2011, 06:35 PM Thread Starter
smokeum99ta's Avatar
Just got studded. How much more power is there really w/ stock injectors left in the tune? Also what about deleting the egr? After reading on these forums alot a people say that deleting the egr wont free up anymore power, but others (and some local people ive spoke with) say they feel a definate power gain. After looking at a egr kit I just cant see how it makes more power but I can see how it might spool faster. Anyone got any input on this?
smokeum99ta is offline
post #2 of 4 Old 01-09-2011, 06:38 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
The studded tunes will push more boost and a tad more fuel and timing. It will prbably net you about 15 HP.
As far as the EGR delete adding HP, probably not. My turbo whistle is louder and it spools quicker now with the delete, though.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #3 of 4 Old 01-09-2011, 06:41 PM Thread Starter
Thats pretty much what I figured. Thanks
post #4 of 4 Old 01-09-2011, 07:00 PM
Diesel_N_Blood's Avatar
From what I understand about egr systems, deleting it would have to give you alittle bump in power. The purpose of egr is to introduce dirty air into the combustion camber to keep the cyl temps done to reduce the nox output. If intake charge is all clean air then how could it not give you a boost in potential power.
Grant
05 f350 SRW SCLB 240,000miles
ARP Studs
SCT x3 (custom tunes by Vivian)
4" MBRP TB straight w/ 5" tip
Airdog 2 w/ factory reg blocked
Hellman sump
Ccv reroute
Zoodad mod
Fleetgaurd elc
coolant filter
high idle mod
egt, fuel press, oil and coolant temp in quad pod
08+ PF/PT Tow mirrors (all using factory switches) and tail lights
Quad fogs w/ 4600k 35w HID's
4600k 55w HID headlights
Diesel_N_Blood is offline
