PHP FICM tuning - Ford Powerstroke Diesel Forum
Old 01-07-2011, 05:06 PM
PHP FICM tuning
Well after I get my new HPOP in the truck I going to do alittle tuning until I sell her down the road. I thought about having PHP tune my FICM while its down and then get a SCT and 4" straight pipe. Figure if I am going to have to drop the money for a HPOP I might as well keep the truck till summer or so that way I get use out of it. Then just return it to stock when I go to get rid of it.
Old 01-07-2011, 05:38 PM
So you are going to sell it? Just do the HPOP and be done. Unless it needs more work.
Selling a truck, tuning may not be a good sign for the buyer.
Old 01-07-2011, 05:42 PM
I will sell it but it wont be for another 6 months or so. I will return it all to stock including the exhaust. I want the FICM tuning for the inductive heating for cold weather starts cause my truck sits at our shop at work for weeks on end cause I work on the road so I want better cold starts.
Old 01-07-2011, 05:47 PM
What oil do you use?
If you dont use it already,using diesel kleen will keep the diesel fuel in good shape.
Old 01-07-2011, 05:53 PM
I use T5 and have Rev-x in this oil change. I also use Diesel Kleen and the Ford addative when I can get in to get it. FICM test out good all injectors test out good. Only work they said was the HPOP needed replaced.
Old 01-07-2011, 06:07 PM
Nice!
What temps do you start it at?
Old 01-07-2011, 06:14 PM
Soon will be in the teens but before long we will be hitting below 0. Last winter I had my 00 cummins and NEVER plugged it in and would fire with ease at -5 and worse. With it sitting at the shop I want it to start as easy as possible since I cant plug it in there.
Old 01-07-2011, 06:23 PM
It must be the prolonged sitting the truck does that gives you the difficult cold starts.
I started my truck when the engine was 20*, no issues at all. I posted a video a few days ago.
My opinion is that the php tuning is a waist of your good earned money.
Old 01-07-2011, 06:37 PM
Why would you think it would be a waste of money? Unless I read wrong its only $150 to have it done.
Old 01-07-2011, 07:01 PM
Well you dont drive it that often, I do not feel that it will be a full benefit from its cost.
I originaly thought it was $200.
