Fuel Crossover tube ?'s
I am in the middle of upgrading the fuel system and don't know how to go about making a crossover tube. Could I use the old banjo bolts that were upgraded in the rear. What is the tube supposed to be made of. Cuase I really can't afford to have a fuel leak at the rear of my engine. I know there is alot of heat back there. I work at a construction machinery dealership so I can make or get anything. Would just like so input on what works and what should be avoided.
Thanks Grant |
use JIC fittings and stainless line, or you can just buy one from dfuser for 100 bucks thats premade, thats what i'm doing when i get the time to install it.
What are you currently doing for mods? The rear really doesn't need to be crossed over.
As of now all mods are in sig., but I am planning on 190cc cass injectors and a powermax. Also saving for AD-II and return reg. Thought that this was a preventive measure to keep rear injectors from having a fuel press. drop and scoring.
Getting rid of the deadhead on the back of the heads with a crossover line using 190's and an airdog is highly recommended no matter what. It can me made for under $100 bucks if you do it yourself, its a great piece of mind knowing those back two cylinders always have proper fuel
How are they routed?
edit....just looked at dfuser, I thought it was solid stainless. |
