Injectors and turbo question
In the future, I'm looking at upgrading to bigger injectors and a Powermax turbo. My question is, if I go with 165-175cc injectors and a Powermax would I make it to 500 rwhp? Also, I do quite a bit of towing, sometimes up to 18k-20k. Will I still be able to tow with that setup safely?
The short answer is no. Kevin McGray dynoed at 550 with Cass 190's and the PowerMax turbo. Once you get past 155's, your EGT's will be too high while towing with loads that heavy. You may be able to offset the higher EGT's with water injection and a combination of tuning. With my PowerMax and stock injectors and a mild tow tune, I can still make it to 1400* while towing.
With that much weight 175 will be hard to do. less than 175cc would be best.
Well, that sucks. Probably just stay with stock injectors then.
If you tow heavy stock injectors are the way to go. People that don't follow that advise and think they'll learn to live with the "compromise" usually wind up beating their heads against the wall later...
Oops, I was not thinking straight.
