What else should i do while torn down for studs and egr delete? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-06-2011, 03:25 PM Thread Starter
DeWitt's Avatar
Hey guys, im planning on ordering my studs with the black onyx and an egr delete. But first im trying to get anything else i should do while its tore down and while im spending the money. Any other suggestions?
DeWitt is offline
post #2 of 12 Old 01-06-2011, 03:39 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
What year truck??
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 12 Old 01-06-2011, 03:45 PM Thread Starter
DeWitt's Avatar
oh sorry i forgot. Its an 05 f250 and all that is done to it now is the k&n intake and custom 4" straight pipe and sct
DeWitt is offline
post #4 of 12 Old 01-06-2011, 07:10 PM
smokersteve's Avatar
Quoted: 20 Post(s)
How many miles?
machine the heads, coolant filter, bypass oil filter, updated turbo oil drain tube, drill out or buy bigger fuel banjos, clean the intake manifold, wrap the exhaust manifolds up-pipes and down pipe, fuel psi gauge, oil psi gauge, check your FICM.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #5 of 12 Old 01-06-2011, 08:00 PM
ebusa's Avatar
get an updated STC fitting...
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #6 of 12 Old 01-10-2011, 02:16 PM Thread Starter
DeWitt's Avatar
What kind of hpop should I get? Another factory one or after market? And what is the benefit to a swamps diesel ficm?
DeWitt is offline
post #7 of 12 Old 01-10-2011, 07:12 PM
paradiserfd815's Avatar
Swamps ficm's use heavier electrical components than oem and also use lead solder instead of leadfree. Ten times the ficm for around the same dollar as ford. I've been running one for three months, starting it at 0-15 below the last couple of days, she fires right up with very little effort. One of the best investments i've made on my truck.
paradiserfd815 is offline
post #8 of 12 Old 01-11-2011, 08:42 AM Thread Starter
DeWitt's Avatar
Which do you have the normal or hot? And what is the diff in the hot?
DeWitt is offline
post #9 of 12 Old 01-11-2011, 08:57 AM
CaseyB's Avatar
Oil cooler core replacement
CaseyB is offline
post #10 of 12 Old 01-11-2011, 10:05 AM
I win....
cRaZy8's Avatar
Quoted: 47 Post(s)
Garage
I have the same year truck, and did the same tear down as you last year.
Heres my list of parts:
Black Onyx HG's
ARP Studs
Send heads to machine shop, mine were near perfect, no cutting needed
Updated HPOP STC fitting
HPOP screen (should have bought the stainless aftermarket!)
Intake manifold sent to machine shop for cleaning
Intake manifold gaskets
Updated turbo drain tube
Diesel Site coolant filter
Oil cooler replacement kit from Ford
Injector seals/o-rings
Glow plugs & harness'
Fuel filters
Predrilled exhaust manifold for EGT probe and put in 1/8" NPT plug
EGR Delete
Probably missed a few other things.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
