SCT transmission settings
I have a SCT from Innovative and looking for a better overdrive lock up at lower speeds. Any suggestions on the settings? Thanks
You want the truck to shift into overdrive earlier? Or do you want the torque converter to lock up earlier?
Neither can be done in the manual settings on the programmer. Call your tuner |
Can I adjust shift points?
Enter the correct revs per mile for your tires and it will do it for you
but that will change ths speedo?
I cant do individual shifts points? |
No you cant do individual shift points. If you want to change them contact your tuner. I dont know of any tuner that lets you change your individual shift points |
as said above if you want this contact IDP. i would think that the file is programed that way to "protect" your truck from extra stress. but you have a custom tune and you can advise them on what you need changed.
