EGT probe installation in Stafford VA area - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-05-2011, 02:58 PM Thread Starter
elnonio's Avatar
I just got my Insight CTS and EGT probe. Local Meineke quoted me 4hrs work time (i.e. $400) and the cost of 2 drill bits to install... WTF? They actually expect to break 2 drill bits, and they want me to trust them with my truck?!
So, unless I'm missing something, I'm looking for a decent shop in the Stafford VA area to have the probe installed.
Any suggestions?
2004 Excursion Ltd
2005 Dodge Magnum
2007 Nissan 350Z
1999 Triumph Daytona
2005 Suzuki DRZ400SM
elnonio is offline
post #2 of 9 Old 01-05-2011, 03:03 PM
Raul@Stealth Automotive's Avatar
wtf! i have had the same drill bit for about a year now and i cant even count how many times i have tapped a manifold with it... its actually not that hard.. the drill and tap will cost u under 20 bucks...
if i were you i would just do it yourself.. all u need is a drill, the bit and tap and some wd40
-Raul
Raul@Stealth Automotive is offline
post #3 of 9 Old 01-05-2011, 03:12 PM Thread Starter
elnonio's Avatar
No tools on hand, still in the process of PCSing and all my gear is in government storage.
2004 Excursion Ltd
2005 Dodge Magnum
2007 Nissan 350Z
elnonio is offline
post #4 of 9 Old 01-05-2011, 03:21 PM
artsamm's Avatar
The following is a link to drill and tap for the probe.
Can you buy the bits and tap and go to your Auto Skills/Craft shop on base to do this?
I wouldn't let the other shop do it, especially for $400
3-Gauge Install Pictures
artsamm is offline
post #5 of 9 Old 01-05-2011, 03:28 PM Thread Starter
elnonio's Avatar
True, I forgot about those. Last duty stations (DLI and NPS) didn't have one, but Quantico does...
Guess I should start gathering all my oils, liquids and filters to do a baseline change of all items to get a fresh start while I'm at it. Wish someone had compiled a complete list of all preventative items to perform when getting one of these; can't seem to find one.
2004 Excursion Ltd
2005 Dodge Magnum
2007 Nissan 350Z
elnonio is offline
post #6 of 9 Old 01-05-2011, 03:53 PM
artsamm's Avatar
When I bought my used 2004, I changed oil and filter, flushed trans, changed fuel filters.
I pull a camper some, so I change oil every 5000 and fuel filters every 10000.
Lots of threads and info here about things to do to make for a more reliable truck.
You can save money by doing some things yourself if you are so inclined;as you posted about the 400 buck hole. Dealer wants 119 to do a fuel filter change; I buy the filters for 50, takes me less than half hour. That's big savings to me.
Again lots of info on here, all for the taking.
artsamm is offline
post #7 of 9 Old 01-06-2011, 04:01 PM Thread Starter
elnonio's Avatar
Lots of info, true, but a lot of straw to sift through to get to the good stuff...
2004 Excursion Ltd
2005 Dodge Magnum
2007 Nissan 350Z
elnonio is offline
post #8 of 9 Old 01-06-2011, 05:04 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
You will find some info toward the top on the main forum page under "6.0 Tech Files". 6.0 Maintanence Info - Ford Powerstroke Diesel Forum
As far as what name brand oil, will depend who you ask, everyone has there favorite. Depending on cost and availability.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 9 Old 01-08-2011, 04:11 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 156 Post(s)
Pull the wheel well liner to help with the R&R of the manifold. I swapped mine out just to prevent any reason to F.O.D. the turbo.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
