Best Cold Air Intake
This is my next investment for my 2006 6.0 was wondering what one would be the best one to get or if i should just leave it stock, i currently have a 4in turbo back exhaust, 2.5inch lift, 35in toyo m/t
I would just do the zoodad mod and leave it stock......better filter and all the air you will need for what you are running.
Do you have a Coolant Filter System yet? Take the $ you were going to spend on the intake and get a Coolant Filter system.
If you feel you want to do something with the intake, just get an CFM+ intake elbow, and I think you can get a AFE drop in filter for your stock system (not sure). I noticed my engine running smoother with the elbow when I installed it. I also used the pre-drilled port to hook my aftermarket boost gauge up to. |
save the money and leave the stock intake.. it will flow more than enough air... i would spend that money on a set of gauges...
-Raul |
yep gauges or coolant filter or oil bypass system would be an better investment.
EGR block and coolant re-route, or egr delete.
Coolant Filter. Buy a kit or buy the parts individualy for cheaper. Oil, Coolant, EGT gauges. Trans gauge is good to add if you can. The Edge Insight is a good buy, it gets all of that and more. Oil Bypass kit. You can buy one for over $300. Or buy the parts individually for under $150. I did this, I found the oil filter mount for $20 and got the filter cap from nuc for ~$60. Oil bypass kits http://www.amsoil.com/a/By-Pass-Filters-Mounts Coolant Filter kits. http://www.dieselsite.com/index.asp?...ROD&ProdID=324 Last edited by Granny; 12-30-2010 at 02:52 PM. Reason: links to non-supporting vendors |
thanks y'all i just ordered isspro ev2 egt,boost, and tranny temp gauges
let the modding begin lol
ive got an afe stage 2, and the ONLY reason i have it is because i drive a lot and its the hell of a lot easier to change/clean an AFE filter then the stock filter
