Checking Codes ? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-29-2010, 01:22 PM Thread Starter
Checking Codes ?
I have an older Hypertech ( I think ) programmer that I cannot use .
It will not interface with my ECM since the dealer did reprogramming about a year ago ( or at least it will not download the programmers per say , I called the company and they said that it was obsolete and would give me a trade allowance for the upgraded one ) ....... as I posted on here my 6.0 is way down on power on another thread ,
If I can get this thing download the diagnostics ? which it should ? I hope ...
Think you guys could dechiper the codes ???
'05 F250SD > Ranch Hand HD Bumper w/skid plate & KC's, 2.5" Leveling Kit, Firestone Rear Bags, 305/17 Goodyear Wranglers, Hide-a-Ball Hitch, SCTx3 by Vivian , EGR Delete, 4" open exhaust , 6.4 Banjo Bolts , Fuel Reg. upgrade kit , cold air intake by me , '03 Turbo by HPTurbochargers,46 gal.aux.tank, ARP Studs / Factory Gaskets.
Rmorgan711 is offline
post #2 of 15 Old 12-29-2010, 01:30 PM
STANGMAN893's Avatar
Shouldn't be too hard.I have found codes and answers just by googling them.Give it a shot you've got nothing to lose at this point.
STANGMAN893 is offline
post #3 of 15 Old 12-29-2010, 01:33 PM Thread Starter
Yea I figured someone else had done this ........just gotta find the dang thing now ....LOL
It may be in storage ? or under my truck seats ? have to look after I get off today ...hope I kept it !
post #4 of 15 Old 12-29-2010, 01:39 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is a list of "P" codes.
~~~6.0 Trouble Codes List~~~
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 15 Old 12-29-2010, 01:42 PM
Powerstroke Techie
Lilpooh's Avatar
You will find lots of info here also along with p codes.
PDF Tech manual
Lilpooh is offline
post #6 of 15 Old 12-30-2010, 05:04 AM Thread Starter
It was a SuperChips Programmer I have ...
here are the Codes it Pulled off >
DTC3 PO336
DTC2 PO404
DTC1 PO460
Besides telling me what these mean , can anyone tell me WHAT to do to get them fixed and is it something I can do ? or does it have to see the Dealers again ?
Do these codes have anything to do with why my truck runs without full power ?
post #7 of 15 Old 12-30-2010, 05:09 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
P0336 is a crank sensor code
P0404 is an EGR code Is your EGR deleted?
P0460 tells me your fuel level sender is bad
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 15 Old 12-30-2010, 05:49 AM Thread Starter
Dave,
EGR is not deleted yet
Fuel sending unit is probably because I have an aux. tank hooked up and tank is completely full to filler neck when I run valve open ? possibly over stroking sending unit arm ?
Crank sensor ..don't have a clue about unless it has failed and dealer told me it was my HPOP ? that put it in the shop awhile back ! if so thats a crappy deal !
I cleared the codes but did not get a chance to drive it last night , if something is wrong it should re-issue the codes right ???
post #9 of 15 Old 12-30-2010, 05:54 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Pull and clean your EGR valve. Its stuck open
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 15 Old 12-30-2010, 06:12 AM Thread Starter
did that night before last , had very minimal coking , cleaned and replaced , maybe it sensed it was unplugged ?
