600hp+ how to get there? - Ford Powerstroke Diesel Forum
Old 12-28-2010, 06:47 AM
Im looking at gettin over 600hp, I'm lookin at liberators Oringed heads, I got studs, also a ad2 with itp return system, i have a extrude honed intake manifold and a egr delete setup as well. I'm looking at the oil cooler delete from liberator. I havent decided on elites or Innovates hybrids, possibly RCD 255mm+, I haven't decided on a turbo because I want a vgt turbo but the biggest I have found so far is a 66mm, I have also looked into straight vain turbos 68mm+, I heard RCD is getting ready to release a 74mm but I'm afraid of the massive amount of turbo lag and what issues I would have with getting it lit. I have also looked at elites hpop upgrade. I also have a ATS torque convertor and billet input and output shafts on the trans
My thought
Liberators heads/hypermax gaskets
Adrenalines HPOP
350cc Hybrids
RCD 68mm
Old 12-28-2010, 07:21 AM
What are you going to do with this truck? That 68mm will not be streetable.
225s and a 66 non VGT will get you very close to 600 and be alot easier.
Old 12-28-2010, 07:31 AM
I wouldn't suggest buying RCD injectors.... Get some 225s from a reputable source and go with twins. You'll have very streetable 600HP
Old 12-28-2010, 07:40 AM
Well right now I have 205s with a vgt-ss it's getting me at the best 556, I'm going to hook this up on the sled, it will be driven on the street Friday and Saturday night, besides that idk what the truck gonna be used for.
I just got off the phone with Garret at EDE and I think I have decided im gonna be running 315cc Hybrids, 71mm VGT Billet Turbo, Adrenalines Upgraded HPOP, PnP +1mm valves heads, stage 1 cam, 165 ad2.
Any other suggestions
Old 12-29-2010, 04:07 AM
My suggestion is when you send injectors in for cores, just swap even with me, my stock ones for your 205's ... sounds good!
Old 12-29-2010, 04:38 AM
i agree with this thats what i got now ecept i have water meth and im close to 600. im swaping my 225s for 305 hybrids. they are supose to be alot better so im thinkin ill have 600.
im also wonder what will the truck be used for? that will help us give better input
Old 12-29-2010, 04:55 AM
subscribing
Old 12-29-2010, 06:29 AM
Almostdunfukinwidit
Go with either 225's or 285's otherwise you will loose all streetablity without either twins or a procharger setup
Old 12-29-2010, 12:51 PM
Well I talked to EDE and I am ordering 315cc Hybrid and I'm going to use a 71mm Billet VGT turbo, i have a built trans already and studs, but I don't have a fuel system installed, I have a 150 AD2 but I have questions on how to install it and should I buy ITPs regulated return ir what since I have a regulator on the ad2
Old 12-29-2010, 12:52 PM
And is there anything else I should do to support those mods
