egr delete = less mpg? - Ford Powerstroke Diesel Forum
Old 12-24-2010, 07:11 AM
Hello! First post and my first diesel so here it goes. Just bought a 05 6.0 250. Bought the truck before I knew what a nightmare these motors are. Good thing I discoverd this site. After checking out the forums I realized I had a bad egr cooler and cracked up pipe. So I got the sinister egr delete kit with oil cooler. Had a local diesel shop install the delete for me. Truck sounds much better now. Strange part is my mpg went from 16 to 11. WTF? The block off plate is installed but the egr valve is still plugged in. Any help is appreciated! Thanks!
Old 12-24-2010, 07:23 AM
are u basing it off of the lie o meter or hand calculated???????
Old 12-24-2010, 07:45 AM
Are you letting your truck idle a lot more b/c it's cold? That might drop it a little, but not 5mpg.
What kind of boost are hitting? It may be a boost leak when everything was put back together.
Old 12-24-2010, 07:55 AM
Mpg was takin off the dash. Ive gone about 100 miles or so. Gettin good boost, up to 28ish when floored. before it was 20ish
