Tuners and the 6.0L- Technical Questions - Ford Powerstroke Diesel Forum
Old 12-23-2010, 06:13 AM
The Silent Service
I don't know much about the tuners that are on the market, and that's a big part of my hesitation in installing one on my rig. I want to know whats going on with the tunes. I have a few questions that I have not been able to find answers on:
If I have a parameter, most likely EGT, going out of specifications, do any of these tuners defuel the program, or return the truck to stock?
When its cold is I don't want to have a tuner dumping a "tuned" fuel level into the engine 'till its up to normal operating temps. How are these tuners programmed for cold weather, say 20 degrees or less?
How do these tuners (which I understand are the Edge and SCT) doing when they tune the transmission to the new powerbands? Is it just shift points, or do they handle fluid pressure and the TC as well?
How are these tunes tested, particularly the custom files, when it comes to power outputs and towing performance?
I understand there is a strong following here for the SCT, and the Edge tuners on the forum. I'm just not ready to flash that computer until I know exactly what its going to do to the truck. The power and transmission tunes from these two sound great, I just need a little better understanding of what is going on.
Old 12-23-2010, 06:16 AM
Almostdunfukinwidit
Custom SCT files are the way to go for tuning on the 6.0 Any of the custom tuners mentioned here are very good at what they do.
Now on to your questions.
EGT defueling no. Get guages and control your EGT's with your right foot
Cold weather defueling and trans programming. Yes they all do that.
Tune testing. They are all dyno and road tested.
As far as Edge the insight cs and cts are great monitoring options
Old 12-23-2010, 10:15 AM
Stick with Dave's recommendations but stay away from the edge tuners you can do a search here and find a lot of reasons not to use edge tuners. SCT is the only way, to do it right.
Old 12-23-2010, 07:41 PM
i talked to eric at innovative diesel and asked him about how tuning is effected with a cold engine. he said that there are temperature parameters in the tune file so it doesn't put all the extra power on a engine that isn't up to temp. this made me feel more assured and i still and sure to warm the truck up and not get over 10psi until the engine is near normal operating temps. hope this helps.
Old 12-23-2010, 07:44 PM
The Silent Service
So, the cold starts can be handled by the Edge (canned) and the SCT (custom tunes) at a minimum. Good to know, I'll just have to verify that when I get the tunes written. Its a start anyway.
Old 01-12-2011, 02:16 PM
The Silent Service
Bumping this up, I've got the truck in for head gaskets and studs at the moment. Looking at the SCT line of tuners.
Old 01-12-2011, 02:19 PM
innovativediesel.com
you can get what ever SCT tuner you want to buy and custom tunes for a package price.
there are other tuners that have great reps too and i'm sure forum members can give you some insight to what they run and how it works
Almostdunfukinwidit
Get an SCT with custom files.
Old 01-12-2011, 04:16 PM
I would start with either innovative or gearhead just so you know your starting with good tunes then you can tryout others later, that is the path you should go imo
Old 01-12-2011, 07:50 PM
I have had superchips and Diablosport and I run SCT now. Neither of the other two tuners come close to my custom tunes in both power and shifting.
The superchips was not very progressive power at all it was all or nothing with really hard shifts all the time. This was the 1405 tuner I think.
The diablosport 100hp race tune feels like my tow tune from Matt......only Matts shifting is much better. This is also the tune I blew my HGs with. This was the Predator tuner.
Switchin to SCT has been my best programming choice to date.
