stacking programmers
2005 6.0 ..... Im running sct tuned by matt and i was wondering if anyone has stacked two programmers before.... i was thinkin about stacking the edge with attitude since it hooks up under the hood and the sct hooks up under the dash... i no this is not smart and im not looking for ppl to criticize me but just to let me no if its possible
Its possible but you wont get anywhere.
why wont you get anywhere if you stack programmers
you will gain more power with just the custom tunes and the truck will act better.
Think about it, The stock injectors are 130cc (flow less but rated at 130). Custom tunes can use all of that fuel and make it fast as possible with stock injectors and such. Now will adding a electronic box under the hood to modify the custom program be able to add more fuel or change how much fuel the injector puts out? no.... = wont get you anywhere. |
Ive seen the same combo on the dyno.
The stack made a 4-8hp difference in the wrong direction in one case. But usually it was only a 4-8hp difference if any. I'll save you a few bucks if you want to stack something that bad
thats with stock injectors what if you are running bigger injectors and bigger turbo and much more.
it doesn't work. Larger injectors function the same as stock injectors so the principle is the same.
ok that will work for me thanks for the info.
so the only way to get more power from here on out is to get a turbo and injectors?
Or nitrous
