Mounting location for an EGT probe???
Well Merry Christmas to me my insight came in today! I also got the optional EGT probe but im not sure on where to mount it I have a turbo back exhaust and it looks like there is a port after the turbo is that a good spot or is it even an option? Thanks for the help and Merry Christmas to you and your family!!!!
You want it pre-turbo. EGT probe placement
Try this...
3-Gauge Install Pictures 2 stroker |
Thanks guys but for some reason the link that lilpooh posted the pics dont show up on my computer I found that before I posted (it still is more than likely my fault) the other one posted by blacksmith I got to open is that the passenger side would you a 7/16ths drill bit and a 1/4 20 tap? thanks alot and im sorry im still in nead of alot of learning alot!
woops its the drivers side
7/16 ( 3/8 also) is bigger than .339. Do not drill too big for the tap or you may be screwed, and not in a good way. Make sure it is a NPT tap as directed. |
^^^What he said^^^
For the tap... I used a 9mm/12 pt socket, the tap will fit in it perfectly. I used 4-5 rounds of electrical tape to hold the tap in place and took my time. Also used a vacuum with the small 'crevice' attchment to clean up after I drilled and after I tapped. Pretty easy job |
