egr delete and still puking - Ford Powerstroke Diesel Forum
Old 12-20-2010, 02:47 PM
I have head studs and a egr delete but when I get on it pukes out the degas bottle. what is up?
Old 12-20-2010, 03:12 PM
if you have an egr delete and its still puking its most likely head gaskets... its possible that when the studs were done and the heads were not checked for flatness and caused the HG's to blow again.
Old 12-20-2010, 03:41 PM
How will I no It runs great. never over heats. EGTs never get over 1100. There in no coolant in the oil. No tunes yet
Old 12-20-2010, 03:47 PM
never over 1100 @ WOT
Old 12-20-2010, 05:00 PM
What are your oil temps?
Old 12-20-2010, 05:07 PM
That is the only gauge I don't have. I will be ordering one now though. The truck has a external oil cooler on it. It is taped into the top of the oil filter cap and dumps into the oil fill tube.
Old 12-20-2010, 05:26 PM
Do you have to lift the cab off to do the head gaskets when it has studs?
Old 12-20-2010, 05:30 PM
Mine ran great and had 5 out of 8 cylinders blown! If it is building pressure before the engine warms up it could be the hg. also if you let it sit over night and there is still pressure in the morning then it could also be hg. I am no expert but everything I read said if it has exces pressure then they are blown.
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
no,you can do it cab on....
Old 12-20-2010, 05:46 PM
Well I checked the degas bottle no pressure. It has been setting for about 3 hrs. temp gauge reads cold. What else can cause that.? Is bad head gaskets the only thing that does that?
