What tune to go with - Ford Powerstroke Diesel Forum
Old 12-19-2010, 04:49 PM
I have a egr delete and 4" turbo back no cat or muffler. What is the highest hp tunes I can use with out head studs. Thanks for the help.
Old 12-19-2010, 05:30 PM
subscribed
Old 12-19-2010, 05:41 PM
Without ARP studs it a roll of the dice but if i were to get one it would be SCTX3 because it also tunes the trans.
2 stroker
Old 12-19-2010, 06:37 PM
Matt's SRL has a pretty good record on non studded trucks.
Old 12-19-2010, 06:40 PM
Raging Lunatic
^^^ Yeah, what that guy said.
Just talk to some of the different tuners and give them the lowdown, let them guide you in the right direction. They sure don't want you bashing them on the boards if you have trouble, so they'll give you the right tune.
Old 12-19-2010, 06:48 PM
I guess I should put I have a sct sf3. I bought it used and it came with two idp tunes. Extreme street and extreme race. It also has 5 canned tunes. I'm not sure if these tunes are ok to run with out studs.
Old 12-19-2010, 06:51 PM
Well since you bought it used the IDP tunes are probably not for your strategy so I wouldnt recommend running them. Canned tunes are alright but custom tunes are much better.
Old 12-19-2010, 06:52 PM
Raging Lunatic
Unless it matches your trucks strategy then those tunes are worthless to you. As I said just call some of the tuners and discuss your goals.
My strategy is the same as the guy I got it from.
Old 12-19-2010, 06:53 PM
Raging Lunatic
Load 'em and try 'em!
