Insight CS, good to go or update? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-10-2010, 06:37 AM Thread Starter
Full-time RV'er
theblacksmith's Avatar
Send a message via Skype™ to theblacksmith
Just got my CS Insight from XDP. Kyle was really good in responding about my order. Kudos to him!
Is it good to go for installation or does it need any type of firmware update prior to installation? Will be installing tomorrow / EGT probe. I'm also looking forward to the (possible ?) upcoming Fuel pressure probe/sensor.
Thanks
Danny
As iron sharpens iron, So one man sharpens another.
Proverbs 27:17
'05 F350 4X4 CC
CCV Mod, 4" MBRP Turbo-back exhaust,
Zoodad, Recon Cab Lights, STC Upgrade, & Dummy Plugs, New Oil Cooler
EGR Delete, OCS Oil Bypass, DieselSite Coolant Filter, New HPOP
HG / ARP Studs, Banjo Bolts, Fuel Regulator Kit, SCT,
Looney Tunes, Edge Insight, Insight Fuel pressure, Turbo Timer.
theblacksmith is offline
post #2 of 4 Old 12-10-2010, 02:48 PM Thread Starter
Full-time RV'er
Lil help
Danny
Proverbs 27:17
'05 F350 4X4 CC
post #3 of 4 Old 12-10-2010, 05:45 PM
bondsman's Avatar
It should be good to go, but before you install it. Hook it up to your computer to see if there is a newer firmware/software revision. I think it is donw with the cd that came with it (my fusion). I too have one, but it is wrapped up under the tree.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #4 of 4 Old 12-11-2010, 11:40 AM
MaydayMay's Avatar
Do the uploads its easy and you know you have the latest stuff in it. Love mine, plus you can put in your own pics if you want on the screen. If you need any help with it Edge was great to deal with.
MaydayMay is offline
