Those running 190cc injectors - Ford Powerstroke Diesel Forum
Old 12-07-2010, 05:35 PM
What kind of fuel pressure are you running and what do you see at WOT?
Old 12-07-2010, 05:45 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
still worried bout that dang fuel psi!!!!! good,it pays to pay attention!!!
anyway,i bought a new computer dude,i said hell with it and bit da bullet..
and sorry if i derail ya thread,its a bump though...
p.s hurry up and burn your tranny up....i miss tuscaloosa
Old 12-07-2010, 06:59 PM
Running 190s on Eric's extreme street. I have a stock system with updated FPR spring and 6.4l banjo bolts. My fuel pressure stays at 68psi until I give it half throttle and it will drop to 60-62. That is normal driving and passing people, taking off, speeding up, etc.... I tried the WOT once and it plummeted to 20psi. My mpg is 17-20 too.
Next, I am going to upgrade the feed lines to the heads, then a regulated return. I just want to see if the stock pump will be able to keep up with the 190s if given the chance.
Old 12-07-2010, 07:54 PM
I wanna go fast!!!
Im runnin 185's and my psi is from 58 to 55.
Old 12-08-2010, 12:13 PM
how in the hell are you guys getting such good gas mileage... i would kill to have 15-16 and some of you guys are 19-20s
Old 12-08-2010, 01:20 PM
Mine stays at 62 and drops to 58 at WOT but I have a AirdogII.
Old 12-08-2010, 01:27 PM
I was just as shocked.. I figured mine would drop from 13. I am getting a lil better than 18 on the low side because my speedo is off by about 6 @ 55.
Old 12-08-2010, 01:52 PM
I wanna go fast!!!
What is the best Fuel PSI to be running at? I have an Air Dog II with the adjustable regulator. I might need to turn it up a bit.
Old 12-08-2010, 02:35 PM
70 is max for the injectors. Any more and you are asking for problems. 45 is the minimum. I would set it around 65.
Old 12-09-2010, 02:12 AM
Mine does the weirdest thing. I have a regulated return too so I have to mess with it a little to figure out what PSI the airdog is putting out. Ill get it set and at idle its at about 55 and will get as high as 65 when accelerating and at WOT its at about 55. Later that day I come back and start driving my truck around and at idle its at 60 and would start to hit 75 when cruising then back down to about 60 at WOT. I did not change a thing since I last drove it. So I adjusted it again and now I'm at 60 psi at idle and it will go up to about 63 while cruising and down to 53-54 at WOT. I'm hoping I dont have to mess with it again.
