Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 06-27-2007, 07:12 PM
jonstar jonstar is offline
Steering whine with 6-inch lift and 37's
there's been a little whine when turning the wheels at a low engine speed from time to time, now it is doing it all the time every time.. low speed, high speed whevever....
power steering fluid is full, nothing leaking around the pitman arm area (a friend told me to look at the top of there) it doesnt sound as deep of a whine as when the power steering is empty... any ideas ? steering box need to be replaced ? does it make these noises ???
Thanks guys!
Old 06-27-2007, 07:51 PM
codman02 codman02 is offline
Mine was doing the samething i put some Lucas powersteering fluid in mine and the whine seemed to go away,,, my
Old 06-28-2007, 08:22 AM
ok great ill give that a try... did you just add lucas to whats there or did you drain the system ? cuz mine shows full currently, and i dont want to overfill..plus im not a huge fan of mixing fluids ...
Old 07-05-2007, 07:41 PM
mdhayden mdhayden is offline
new ball joints
At 58000 miles I had whine in my steering. I was convince it was in my power steering pump until one day I let my truck roll down the driveway with the engine off and it made the same noise. Took it in to the dealer and they replace the ball joints.
Old 07-06-2007, 11:12 AM
thanks for the reply... i thought to shut the engine off while rolling to check for the sound... but never did because the idea of stopping an 8,000 lb truck with no brakes didnt sound too good to me.
