I Need Help! What else does this truck need??? - Ford Powerstroke Diesel Forum
Old 12-01-2010, 06:37 AM
So im looking to buy this truck and im wondering if it needs anything else to make it more reliable. '06 F250 Reg Cab 4x4 42k miles
List of mods:
Full built Suncoast Transmission
Elite Diesel stage 3 injectors
Elite Diesel fuel system
5" MBRP exhaust
Custom 70mm turbo 40-45+ psi of boost
Afe stage 2 intake
Accufab intake elbo
Spearco Intercooler
Custom fan schroud with electric fans
Moly roll cage with racing belts
Drive shaft hoops both front and back
Nitrous Express 2 stage
Nitto drag radials on all 4 corners
Detroit true-trac posi rear
Turbo after oiler for cooldown
Egr delete kit
ARP studs
Old 12-01-2010, 06:42 AM
and it has SCT tuning from Elite Diesel but im thinking about going with Matt or Eric.....
Old 12-01-2010, 07:37 AM
coolant filter.
CCV catch can.
Transmission cooler
oil bypass filter.
Synthetics in diffs transfercase and engine.
Heat wrapping on the exhaust up-pipes, y-pipe, down pipe.
Old 12-01-2010, 07:39 AM
what kind of key-off oiling system do you have?
Old 12-01-2010, 07:48 AM
can you give me a ball park price range on those items? and wheres a good company to buy them from? can you explain more on the key-off oiling system
Old 12-01-2010, 07:57 AM
it is in your list, "Turbo after oiler for cooldown"
CCV
318
BD Diesel 1032170 CCV Kit for Ford Powerstroke at DieselManor
318
BD-Power Crank Case Vent Filter 1032175
318
BD Crank Case Vent Filter Kit 03-07 6.0L Ford Powerstroke 1032175
335
Outlaw Diesel Performance :: Online Store
Coolant filter
169
KT Performance
119
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
169
Ford Superduty Powerstroke 2003-2007 6.0L Coolant Filter Kit
169
Ford 6.0L Powerstroke Diesel Coolant Filter Kit
Old 12-01-2010, 07:58 AM
Bypass oil filter
Welcome To NUC Motorsports manufacture of oil bypass filtration kits for Ford, Chevy, and Dodge, Ford 6.0 billet aluminum oil and fuel filter caps and more...
Mobil 1 5W-40 for the eng
amsoil for the diffs and transfercase.
Old 12-01-2010, 07:59 AM
US Auto Parts - Catalogs - g126322
And get a coolant additive that also helps to prevent cavitation.
I will soon be using 2 bottles of redline for diesel engines.
Old 12-01-2010, 08:03 AM
Appers to be a all out drag truck? Is that why your a buying it for for a DD?
Old 12-01-2010, 08:04 AM
Yea, the stage 3 (225cc) inj sound heavy on smoke.
