SCT X3 Driver - Ford Powerstroke Diesel Forum
Old 11-29-2010, 05:03 PM
SCT X3 Problems
I have a SCT X3, i downloaded the Updater off of SCTFlash.com but when i try to load a tune it says "Failed to read Device" and then says unauthorized device or something like that. I tried to reinstall the updater but it didn't help any. any suggestions?
Thanks
Bryan
Old 11-30-2010, 08:54 AM
Bryan, what you need to do is go to device manager on your PC and install the drivers for this device. here is a link to show you how to load the drivers and install the device updater. http://www.sctflash.com/software/SCTDeviceUpdater.exe
Old 11-30-2010, 02:56 PM
Well Matt, it says the driver is up to date but it still says failed to read data and not a valid sct device when i try to load a tune. and when i try to check for updates it says can't unlock device. any other suggestions???
Old 11-30-2010, 06:14 PM
I had the same problem...my desktop kept doing that so i used a newer laptop and it worked fine. Is the programmer powering up? It would not power up on my desktop for some reason...
Old 11-30-2010, 07:17 PM
the sct powers up and the laptop is less than 1 year old
Old 12-01-2010, 04:46 AM
If you'd like you can contact me and we can see what the issue is on your PC.
Old 12-02-2010, 03:51 AM
thanks matt, ill be in indy for a couple days but ill get a hold of you th first part of next week.
