Blowing coolant out degas tank ? - Ford Powerstroke Diesel Forum
Old 11-28-2010, 03:53 PM
Is it possible to have a bad egr cooler and not blow head gaskets ?
I lost about a gallon of coolant after running pretty hard for about 100mi. noticed it loosing some lately but not this much ..truck runs great and no smoke or steam out exhaust ?
if it is a cooler can I just leave the degas cap loose as to not pressurise the system and just allow it to vent till I can do the egr delete ?
Old 11-28-2010, 04:26 PM
Read the link in my sig. Your oil cooler is already FUBAR. Fix it now, change the coolant to ELC, and GET A MONITORING SOLUTION!
Old 11-28-2010, 04:32 PM
yup oil cooler. get rid of egr cooler at same time.
Old 11-28-2010, 04:38 PM
oil cooler ??? Oil is clear with no traces of moisture or coolant ? I thought the egr cooler would be bad ? already did the coolant swap ...
Old 11-28-2010, 04:49 PM
If you are puking the oil cooler is already FUBAR. The link in my sig explains this whole sequence of this chain of failures. That is exactly what is goin on with your truck That is why it is CRUCIAL to monitor your ECT and EOT. That is the only way to see it coming. Don't let it go till you are spending lots more money because you didn't fix it while you still had a chance.
Old 11-28-2010, 04:57 PM
So I should do a egr delete and new oil cooler ? please forgive my ignorance ..LOL Just don't uderstand how oil cooler can be gone if ther is no coolant in the oil ...I'm all ears brother and listening ...where do I get the oil cooler ..can I do this myself like the
egr delete
Old 11-28-2010, 05:05 PM
This happened to me I had bad oil cooler it will puke when I would get on it. just do head studs to. make sure you replace your cap after it blows coolant out. It seems every time it happens to me my cap ends up being bad.
Old 11-28-2010, 05:10 PM
1 problem . I'm basicly broke.....
job i am on is 150mi from home and what I make leaves no money for any thing else ...so I will have to try and fix myself so studs aint gonna happen,,,what about some kind of radiator / block sealant ??
Old 11-28-2010, 05:17 PM
well i have a oil cooler kit if you want i can give you a deal on it.. while you are in there do a egr delete. i dont know how good you are with a wrench but you should be able to do it in a day. You need a edge so you can look at your temps.. hopefully your gaskets are good.
Old 11-28-2010, 05:24 PM
Talk to me , I used to be a Fleet Maint.Mgr so yea I can spin a wrench ...just not familiar with Automotive engines ...mostly industrial background....pm me on what I need to do .... I can scrape up money for parts but no way I can swing paying a dealer to do work right now ...
and THANKS GUYS !
