how to save oil cooler?? - Ford Powerstroke Diesel Forum
Old 11-28-2010, 07:16 AM
how are y'all keeping your oil coolers from going out again??.. just a antifreeze filter??.. what about the type of antifreeze??
Old 11-28-2010, 07:24 AM
go with the cooler filter and at then same time flush your system and add elc coolant....you can use the search function on here to read the write ups on the benefits and it will also tell you how to do it.....its really easy did mine last weekend
Old 11-28-2010, 07:28 AM
yeah I've seen that some people use ecl but I couldn't evr find the details on it.. I'll jus surch a little harder.. thanks
Old 11-28-2010, 07:45 AM
Send a message via MSN to dusted4eva
I have the dieselsite coolant filtration and use Amsoil ELC coolant. I wish I took pics of the first filter I pulled off for everyone. There was enough particles to fill a pepper shaker.
Old 11-28-2010, 07:51 AM
yeah I have seen dieselsite filtration.. deff will get that.. where did u get that elc coolant ??
Old 11-28-2010, 08:46 AM
this I wat I found.....
Drain coolant by removing lower radiator hose. Drain block from plug on drivers side of the block. Remove the thermostat. Replace plug in block and put lower hose back on. Put thermostat housing back on without thermostat. Fill with tap water. run for 5 minutes then drain as above. Put 2 qts of VC-9 and fill with tap water. Drive it for about 60-90 minutes. Drain and flush after. Put in 1 gallon of Restore an top with tap water. Drive it for an 60-90 minutes then drain. Flush 2 times with tap water or whatever it takes to come clear. Flush 3 more times with distilled water. Replace thermostat or put in a new one. Put hose back, make sure block plug is tight. Add 3.5 gallons of ELC concentrate and top off with distilled water. Make sure to run engine for 5 minutes between flushes to circulate the water good. Have heater on set to hi while doing this to flush the heater core too.
is it really safe driving it around with out thermostat?
Old 11-28-2010, 09:22 AM
Since you are quoting me I will answer this for you. You do NOT want to go without a thermostat for normal operation of your truck. This is strictly a time saving convenience when flushing as many times as you need to when cleaning out the cooling system and changing over to elc. For the flush to work it has to circulate the water for about 5 minutes on each flush cycle. Without the thermostat it starts circulating as soon as you start the engine. If you leave the thermostat in you have to start the engine, wait for it to come up to temp and open the thermostat to begin circulating the water. Considering that we are talking about 12-15 flushes that becomes significant. Time to pull thermostat = 10 minutes. Extra time to let the engine heat up before circulation begins = 10 minutes x 12 to 15 cycles = roughly 2 to 2.5 extra hours to do the job if you leave the thermostat in. Both ways will work. I recommend pulling the thermostat for the flushes and installing a new one when you are done. They only cost about $20 and it is good preventive maintenance. Hope this clears it up.
Old 11-28-2010, 12:03 PM
put a cleaner in the cooling system after you have removed the coolant and have replaced it with distilled H2O, fill up with ELC, put a coolant filter on the engine.
Old 11-28-2010, 02:41 PM
I ordered it from the Amsoil website maintenance tab.
Old 11-29-2010, 09:43 AM
This has got to be one of the greatest idea's I've ever heard. Can't believe I didn't think about this when I did mine.
You, good sir, are a genius.
