I need schooling on fuel pump setup...
Just finished alot of work to the truck. Here in the next couple of months I am planning on getting an AirDog2 to protect my injector investment.
Now, I am running FF 190's with the Powermax and Eric's extreme street. 6.4l banjos along with the upgraded FPR spring. Normal driving around without romping on it, the fuel pressure stays at 68psi. When I get on it pretty good, it drops to 60. Now, yesterday, I really mashed it to the floor and the pressure plumeted to 20 (not good and won't do that again). So, I am in need of a different fuel system. I have heard many things on here about running a regulated return along with the AirDog2. I have read where people turn their pump way up, then regulate the pressure to the heads via the return. Others say the AD2 is sufficient enough with its own regulator. Now that I know I can't really get on it, I will take it easy until the AD2 is in. Is the reg. return required? It is so expensive... Which AD is recommended. Looking at the 165. But would the pusher type original air dog work just as well?? School me... |
I run the orginial Airdog 150 to my stock pump to the fuel bowl. After that I have a regulated return kit. From the back of the heads into a y-block to the stock pump as return. Mine runs great and no issues.
Im running the Airdog II DF-165 and It works great. I don't have a regulated return. Install was easy and simple. That would be my recommendation.
Down side, if your pump ever goes out you don't have your stock pump so be able to limp home. |
I would not bother with a regulated return with the Airdog but would consider adding a crossover on the back of the heads. I like my ADII 165.
Pgreen- didnt your pump go out on you? Have you had any reliability issues since? What pressure are you seeing when you are really getting on it? Can the AD2 keep up with 190s? Did you make your own crossover?
Add a fuel tank sump and your choice of the AD100, AD150 or the AD II. All will give you the fuel you need for the 190's.
I don't have a crossover setup on mine because of my Vegistroke. The Vegistroke lines feed into the back of the heads and replaces the front banjo bolts with real check valves to keep the WVO from flowing back to the diesel tank. When I really romp on it I lose a bit more pressure than you guys will. I am blowing diesel past the check valve in the Vegistroke manifold and into the WVO tank at WOT. Not bad but enough that it is dropping me about 20 psi. |
