Starting the build....Opinions?
So I've been learning all that I can about my 6.0l getting ready to start ordering a few parts. I don't want anything too serious, just a respectable 400-450 rwhp, firmer shifting and to git rid of the dead spot before the turbo spools. I finally decided to go with the SCT X3 and some custom tunes but I wanted to talk to a diesel mechanic in the area before I ordered anything. So after talking to the owner of a custom diesel shop yesterday, I have a few questions.... According to the mechanic, I need to install head studs, O-ring cylinders and do a coolant bypass at a minimum before I order my SCT. I would love to hear your input, if any of you are running these mods and are they nessesary? I know that the increased boost and cylinder preassure after the SCT will find any weak links in a stock truck faster, but am I really going to blow a head gasket right away if I install the tuner anyway?? -Help please
before you wnat to add power you should defenitly do an egr delete, studs, coolant filter, bypassfilter.
You can get 450 with tuning, good fuel flow and pressure and powermax |
im running my sct with matts srl custom tune on stock everything else. you dont need to have that stuff done first. im just waiting till i need to do it.
you will get 400 with tuing easy.
Depends how you drive the truck, run it hard then it might let go. You dont need o ring heads, I dont run them and Im over 550hp.
SCT EGR Delete ARP Studs Check Heads |
mine heads went bad n I didn't realizes it till I still kept pukeing antifreeze after I did the egr delete.. a couple months later it was back in the shop.. you might wanna go ahead n stud it when u do the delete
