190s and powermax egts????
I am running Eric's extreme street for 190's and powermax turbo. My egt's are between 800-900 at 60mph in OD. Seems they are lower before it shifts into OD.
What temps are you seeing normally? Also when I finished my HG, studs install, I ran the normal extreme street for startup and first couple of miles. It threw some pretty good smoke. Now that it is tuned for the new injectors and turbo, it hardly smokes at all. Power is still the same. I also noticed my lie-o-meter is steadily climbing (at 16mpg now). It was hanging around 13 before. |
well at the lower rpms you will see higher egts because of the air flow is lower.
That sounds about right. I run anywhere from 700*-900* with my SRL. Less smoke with the updated tune is what it is suppose to do. On the MPG I noticed an increase as well but all the way up to 25-28. I know that isnt right so I checked it and I was 18. Maybe its a larger injector thing.
