A little help with my SCT X3 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-23-2010, 05:32 PM Thread Starter
excav8ter's Avatar
Arrow A little help with my SCT X3
Ok, so my new X3 will be here on November 24th. I am completely lost when it comes to updating, downloading and so on. Is there anybody near Holland Michigan that can help me do my up date and then the install correctly? I am very nervous that I will make a mistake and lose a tune or worse my stock file. I don't have the X3 yet. I want to get this thing in ASAP to try it out. I have the tunes that were emailed to me but it looks like there is only one tune even though I am supposed to have 3. Can anyone help me?
Thanks.
excav8ter is offline
post #2 of 11 Old 11-23-2010, 08:07 PM
MoyockPowerstroke's Avatar
Not in MI. but most anyone on here can help you. The best resource is SCT tech....give them a call and they will walk you though everything....they are pretty easy to work with. Also, who did you get your custom tunes from? Have you contacted them and let them know you only received only one tune instead of three? What I would go ahead and do now is go to SCT's site and download the Updater software 2.9.5.2 (it will be the latest version and will create a desktop shortcut icon). Then when you get your device plug it into your PC and check out which Firmware version (FMware) you have and compare it to the SCT download site...if it needs updated then make it so. If you had an SF3 then you would also check their latest Tune Rev....but the X3 only holds custom tunes.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #3 of 11 Old 11-24-2010, 07:49 AM
Matt@SCT's Avatar
is this device a SF3 or X3?
Matt@SCT is offline
post #4 of 11 Old 11-24-2010, 08:08 AM
How do you already have the custom tune(s) emailed to you, when you don't have the X-3 to retrieve the truck strategy # from the ECM? Thought it was required before a "custom tune" could be generated???
2004 F250 CC SB 4x4 Lariat
WIX intake with zoodad mod
(05 & up) Innovative Diesel intake elbow with butterfly valve manifold removed
4" SS T-Back no kitty exhaust
SCT X3 w/ I.D. Custom Tunes
Gauges: EGT, Boost, Tranny Temp
Pace Edwards bed cover / B&W Gooseneck Hitch / Linex
DieselSite coolant filtration system
DC Power Engineering 250A Alternator
Submariners do it deeper!!!
ShawnCT450R is offline
post #5 of 11 Old 11-24-2010, 09:00 AM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
In another thread the OP had originally bought the SCT Livewire and didn't like the size of the monitor, so he sent it back to get the handheld programmer. So I'm guessing he used the Livewire to pull his strategy.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 11 Old 11-24-2010, 12:16 PM Thread Starter
excav8ter's Avatar
It's an X3, Yes I used the Livewire to pull the strategy. Then the livewire was sent back to Innovative in exchange for the X3 with the Edge CS.
post #7 of 11 Old 11-24-2010, 12:49 PM
OIC. Cool. Makes the process that much quicker for you then. This should be easy then.
post #8 of 11 Old 11-24-2010, 01:17 PM
I see you have Matt's attention at SCT....take advantage of his help...he is always on the ball and one of the best techs SCT has...be wise and listen to what he says.
post #9 of 11 Old 11-24-2010, 03:47 PM Thread Starter
excav8ter's Avatar
I also got a P.M from Ted @ IDP.... Man all of you guys are on top of things here, THANK YOU!
Once I get my X3 I will be sure to get with Matt or Ted to get it done right. I am very Impressed that these guys are so willing to jump in and help a newbie.
post #10 of 11 Old 11-25-2010, 07:38 AM Thread Starter
excav8ter's Avatar
Man I am dying to run my truck with this new X3, but there has been a little "glitch" so to speak in getting it all set up. Not sure what, but even today, Ted at IDP has emailed me to let me know that he has been in touch with Eric today and let him know what is going on. That is COOL. For a guy like me who hates doing anything on a computer except for being on powerstroke.org, sledmi.com and dootalk.com this is hard. The wait is really killing me. I am sure it WILL be worth it when I get the X3 and Eric's tunes installed, but I am having surgery soon and won't be able to do anything for 4-6 weeks, not even drive. So I want to get this in so i can enjoy it for a few days.
